Question about Samsung SYNC SGH-A707 Cellular Phone
Water damage my phone went through the washing machine and the screen is a little messed up... anyone know how to fix that??? Also, when i turn the phone off it turns back on by itself a few seconds later My phone is a samsung/at&t sync
    Brigadier General:
  • 7,752 Answers
It is best that you have the phone service....take it to a professional mobile repair shop...also do note that when a phone has water damaged......it may or may not work after being water log.
So let's hope it work
Posted on Jan 01, 2008
Hover nextra hnf7148 ,water comes out of the back of the machine when loading with water, it comes from 3 small holes on the right hand side of the belt.i replaced the carbon brushes about a month ago ,I...
There is a big chance that you have messed up. As i know washing machines comes with 3-4 long bolts attached at back of machine. Which secures heavy inner parts during transportation. If you didn't attach those long bolts before laying your machine face down, inner pieces might be damaged.
Nov 19, 2014 | Washing Machines
The city turned off the water to fix a main line and then turned the water back on. The first time I started the washer after this happened, I heard a loud pop noise and the water began gushing into the...
After repairing the pipeline it's inevitable that some debris/stones/cement etc. would find it's way into your machine. Even though there is (or should be) a filter in the water input hose, I'd guess that the water pressure was so high that some debris damaged the electrically operated solenoid valve which controls the water input flow. A mechanical problem then, with possibly some associated electrical fault. If you can get the machine out, I suggest unscrewing the inlet hose and having a look at the valve - they're usually easy to get to. But please DISCONNECT THE ELECTRICAL SUPPLY AND WATER first.
May 25, 2014 | Asko W6661 Front Load Washer
What can I do to increase the water supply into washing machine AEG Lavamat W1010. It is rather litle water comming into the machine and the washing powder is not total wet because the water is running...
Turn the water off at the wall behind the machine. Note if it takes a few turns to close the valve or not (a partly open valve could restrict flow.).
Disconnect the hoses at the machine. There should be a filter there. Clean that filter.
If there is not a filter there, then remove the hoses at the wall end and check/clean filter.
If a filter cannot be found, then test the water flow from the hose by getting a bucket and putting the hose ends in the bucket. Turn the water on at the wall and note if there is strong flow from the hoses. If there is, then there must be a filter screen in the washer that needs to be located. If there is not, then look for problems upstream in the plumbing system.
Finally, there should be a water level sensor in the washing machine which should force the washer to fill before proceeding (although different water level requirements based on load size impact that sensor.).
Let m e know what you find and I can give you more instruction.
Dec 16, 2009 | Washing Machines
I have a motorola razr v3x phone, problem with water damage
I dropped my in the bath tub giving my little girl a bath. I pulled the back cover and battery out and sat it upside down, back faceing up, under a lap and turned it over every hour. The next morning put the battery in and closed it up, no problems - till the next time it went swimming and had to repete the process.
Sep 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Hey i have an lg rumour havent had it more than a
does it have water damage at all? also have you ever dropped it? because when my rumor had water damage, the screen went white.
Aug 27, 2009 | LG RUMOR Cellular Phone
My same type of phone's screen goes black
My Samsung SCH-r560 screen went black, how can I fix this?
Jul 30, 2009 | Samsung Gravity SGH-T459 Cell Phone
Broken screen on lg dare Broken touch screen. can it be replaced? got my phone wet for a second. dried it off. everything works, but my touch screen will not respond on the left side of the phone. water...
ive had a similar problem... but what i did is i looked at what the insurance does cover... since it doesnt cover water damage.. defect the phone in some way that the insurance will cover. its only if you're in desperate need. there is no way to fix water damage... but i know PLENTY of tricks to soak water out of the phone
May 30, 2009 | LG Dare VX9700 Cell Phone
Slow to fill
wher e the washing machine hoses connect alot of times there is a little screen to catch particulate in water try cleaning it
Feb 06, 2009 | Roper RAS6233KQ Top Load Washer
My Iphone never turned on after little water spills on it.
try keeping the phone in a dry warm place for a number of days even weeks and then see what happens.
Oct 27, 2008 | Apple iPhone Smartphone
Samsung SYNC SGH-A707 Cellular Phone Logo
142 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
