Question about Smeg SE250XUK Stainless Steel Electric Single Oven
Smeg SNZ91MFX1 Fan heating not working
The oven heats as per normal when not on fan bake. When on fan the fans turn as per normal but the oven does not heat.
  • Smeg Master
  • 744 Answers
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Posted on Mar 05, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
Posted on Jan 24, 2008
6ya staff
SOURCE:
Fan bake on smeg oven not heating ,mod SA 9066XS
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 02, 2012 | Smeg Ovens
Heating elements in fan oven not working
Nov 26, 2011 | Smeg Ovens
I have a Smeg SA 398x model. firstly, I would like to know the year of manufacture please. Secondly, for some reason the fan element options do not heat up. The fan in the back of the oven works but no...
Jul 19, 2011 | Smeg Linear Pyrolitic Single Oven Electric
I have a fan assisted double oven smeg tipo R31 mod SP 9000x/1 and my latest 2 batches of muffins have not baked.When I have taken them out of the oven they have not risen and are only half cooked. I have...
Jul 08, 2011 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Does not heat up fan turns on smeg scp 111 multifuncation ELECTRIC oven
If this helped like us on Facebook please
Sep 10, 2009 | Smeg Ovens
Fan but no heat
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg oven
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Nov 05, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
424 people viewed this question
Top Smeg Ovens Experts
Jason Harris
Jason Harris
svoorhees
Level 1 Expert
Are you a Smeg Oven Expert? Answer questions, earn points and help others
