Hitachi 51F59 51 in. HDTV Television
Problem for Hitachi 51F59 51 in. HDTV Television
Hitachi 51f59a lost picture
By brooksolson on Oct 27, 2009
hitachi 51f59a lost picture powers up and can hear sound amp come on when turned on and off but no picture
Solution #1
posted on Oct 28, 2009
Not Rated)
rusty_etech
Rank: Guru  Televisions & Videos  Expert
Rating: 91%, 118 votes
You may have a shorted horizontal output transistor. This transistor drives the high voltage transformer which in turn drives the picture tubes. High voltage can be dangerous so you may want to have a repair shop check it out for you. Also have them apply a bead of silicon around the anode caps on the picture tubes. This will prevent high voltage leaking out and causing the horizontal output to short again. Thanks
Was this helpful?
Yes
No
Popular Solutions for Hitachi 51F59 51 in. HDTV
Questions and Unsolved Problems for Hitachi 51F59 51 in. HDTV
Do you recommend Hitachi 51F59 51 in. HDTV Television?
Answer
Answer
how do i get the best hd picture in the term of video settings and is there an upgrade available
Answer
When i switch on my Hitachi LCD television, the hot bird channel takes over, how can i stop this, i... (More)
Answer
The picture fades in and out, double pictures and picture goes out and there's lines. The picture... (More)
Answer
Heads are too high and vertical needs to be lowered. Heads are cut off at top.
Answer
got a blue tinge, oval in shape around the outer parts of the screen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 51F59 51 in. HDTV...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
