Question about Saeco Classico Espresso Machine
Water Too Hot, Coffee Too Watery
Our SAECO Classico has been behaving very randomly.  The coffee is often too watery.  I think the water gets heated too hot: you can feel it when you drink (indeed you can feel the temperature through the cup) and you can see that, when you prime the machine, the water is hot and steamy.  What confuses me is that this behavior is somewhat random (though these days the coffee is more often than not not quite ok) AND that priming the machine a lot (by taking out quite a bit of water before making our coffee) ultimately does not seem to help: the water seems no longer to be steamy, the flow seems nice, but the coffee is still too watery and - I think - too hot.  Any ideas? Do I have to bring it in somewhere for maintenance?  (PS: I know the problem is not with the quality of the coffee, or the amount, or the grind...  These were all the same when the machine was working just fine.)  THANKS!
  • 1 more comment
  • paduet May 29, 2008
    Hi Johnny Beans:
    Yes, we have done the descaling.
    Hi JohnnyBeans:
    Yes, we have been descaling.
  • Cerini Coffee
    Cerini Coffee May 11, 2010
    Have you been descaling?
I am pretty sure that the thermostat that stops the heating when the temperature gets to 95 degrees Celsius needs to be replaced. Part is available on the net for about $15.00. I'd replace the other theormostat at the same time (it stops the heating when the steam function is on, around 127 degrees).
Posted on Mar 10, 2009
    Sergeant:
  • Saeco Expert
  • 223 Answers
Sounds like there is something wrong with the machine. Could be the thermostats or maybe something like an internal leak that is causing the machine to overheat. It sounds to me like you need someone to take a look at it..
We service saeco espresso machine and are stationed out of New York..
If you need parts of cleaning supplies check out our website:
www.CeriniCoffee.com
Posted on May 29, 2008
Why is coffee dispensed through only one spout on my saeco hd8763 coffee machine, and why is dreg drawer filled with water and not only coffee residu
First, I'm NOT a Saeco technician, But I have worked on similar machines.
*** You should contact your service vendor. Especially if it's still under warranty. The following is for information only.***
* The spout dispencing only on one side can be caused by an uneven table/counter. A clogged spout. and a crooked spout (got banged out of alighnment)
* Water in the dregs. Check if the pucks are watery or there is just water at the bottom of the tray?
* Watery pucks are from low coffee dose or low compression.
* Water in the tray is the overflow from one of the water systems.
* There are really no customer serviceable parts in this machine. Though there are a lot of adventurous people out there that like to tinker with this machine.
* again, call for service.
Aloha, ukeboy57
P.S. check you tube for your model and brand. many sites with D.I.Y. cleaning and servicing of this machine.
Apr 24, 2018 | Saeco Coffee Makers & Espresso Machines
When I use the filter after a previous cup and it is still wet the coffee comes out very watery and undrinkable. When the filter is dry in the morning the coffee is perfect.
I'd suggest you try tamping with a bit more pressure, watery coffee is typically the result of water getting "around" the ground coffee as opposed to getting forced through it.
Feb 16, 2014 | Breville Die Cast 800ESXL Espresso Machine
My Saeco Classico has problem. The pump is working
It sound as though the boiler is blocked by scale. May also be the coffee filter that's blocked. I am not familiar with this machine, but assuming that it's just a manual espresso machine, try running it with the filter handle removed. Any water emerging? If so, the coffee filter cup and/or filter handle outlets may be blocked. If there is only a small flow the boiler is almost certainly blocked with scale and descaling may cure the problem (do the first run with the filter handle off the machine. Next run with it on)
Oct 22, 2013 | Saeco Classico Espresso Machine
Saeco syntia ground coffee chute not working well
The grind on the coffee might be too coarse and instead of making espresso its coming out like drip coffee because the water is running through it too fast.
May 25, 2012 | Saeco Syntia SS Automatic Espresso Machine
Machine is not making coffee
We need some information to be able to help can you describe what is does and what not, do you have water without coffee in it, does it turn on at all, does it heat up, do you get hot water or steam
Feb 21, 2012 | Saeco Classico Espresso Machine
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Saeco Royal Digital Plus Coffee Maker, Espresso Machine
go into the menu and reduce the amount of water the machine pumps through
thanks
Coffee fix
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Incanto expresso machine is producing thin, watery and cold coffee. I have walked through some troubleshooting with a Saeco rep and no better results. The top warming plate stays hot. Water flows...
It sounds like the heatingellement of the boiler is broken.Pump works. you also , if i am right get no hot water if you try that.
You can get the part on line. which will be cheaper than doing it through saeco
Try this link SAECO PARTS
Placing it is not too hard as long as you work methodical.
Apr 28, 2008 | Saeco Incanto Classic Espresso Machine
Vienna Deluxe Coffee Machine - Water doesnt heat up
indeed the heat sensor can be busted. Not a difficlult fix but time consuming as you need to get the whole machine appart.
Go to the saeco site and look in their parts list of your machine. It tels you the part number for the sensor. and you can order it anywhere.
Your boiler can be damaged too.
Kind regards eric
Nov 13, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Classico Espresso Machine Logo
233 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
