Question about XM Radio (XMP6000)
Need to crank the volume to hear XM Radio
I just bought a new audio system for my son's car (a surprise) and have an XMXpressR unit on my dash, wired somehow into the back of my CD player. To play the CD, a volume of 20 is fairly loud. To play the XM, we have to crank it up to 50 for it to sound good. Do I need to take it back to get fixed or is this how they usually work? Maybe I should have had them put the XM directly into the CD player.
  • yankeedude May 04, 2008
    I have an XM Xpress EZ and have the same problem with the volume.When I first got it it worked fine but latter on it lost stereo then The volume quit working.I have to have it cranked to hear it at all.May be the contacts where it plugs in are damaged or worn?
This sound level problem is caused by oxidation forming in the electric connectors of the XM radio. I have tried several deoxidizers. Only one works really great. It is called, Caig DeoxIT. Here is a link to a good place to buy Caig and in the proper size too! [link].
Spray Caig DeoxIT into and over the connector and allow the deoxidizer to work for a few minutes.
Good luck,
George
Posted on Jun 29, 2009
    Problem Solver:
  • 6 Answers
Defently take it back to get fixed it shouldn't work that way. it should be the same or louder when your deck is set to 20 for the volume
Posted on Jan 02, 2008
Pioneer instructions
when tuned to desired station press and hold the selected button eg 1,2,3,or 4 for about 2 sec you will hear a beep sound and it should be saved
Jan 02, 2014 | XM Radio Dual XMP7000 Auto In-Dash CD...
New Xm, went through the steps in manual; no sound in car
The stations you set it to have to be complete static for the xm to come in. Your best bet if you head unit has an aux input is to buy an aux cable(few dollars) and hardwire it. it will give you the best quality for sound for xm.
Dec 27, 2009 | XM Radio (XMP6000)
Need to know how to hook up the wires for the radio
Find a wiring diagram for the audio system in your car (the ones in the Haynes Repair Manuals are excellent). That will tell you what each of the wires sticking out of your dash is. The wires sticking out of the back of the new radio should be labeled, if not, consult the installation manual. Hook the wires from your radio to the corresponding ones in the dash, and you're done!
N.B. It also helps to have a voltmeter to determine which of the wires are hot.
Oct 23, 2009 | Pioneer XM CD RC DET MOSFET50 MP3
XM radio ''NOT READY'' message
I have had this problem at least a half-dozen times, and the simplest solution is to pull the 2 fuses labeled 'audio 1' and 'audio 2.' It resets the radio, but it will work for a while after that (until I have to do it again). Had the xm unit replaced 3 times, new antenna installed, replaced the antenna connection wire - it always dies within a month.
Sep 24, 2009 | 2008 Hyundai Veracruz
"not ready" message on XM radio
Remove the Audio Fuse and then put it back in and the problem is solved. So frustrating that I had to find this solution on another site as both the dealer and XM had no idea how to fix it. Dealer tried to tell me it was a bad radio and I'd have to get a replacement from Hyundai.
Jul 02, 2009 | XM Radio Dual XMP7000 Auto In-Dash CD...
XM Roady is non functional
turn ignition on and disconnect your car battery then leave it on until its done loading if it still there then call xm and have then send an update good luck....
Dec 30, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
Need an In Dash XM Radio Installed on 1997 Honda
where they tear the whole dashboard and rebuild
Jun 18, 2008 | XM Radio (XMP6000)
Need an In Dash XM Radio Installed on 1997 Honda Prelude
well...there is an after market for this, but it's a little high end at this point.
FINDING A RADIO FOR A SEMI TRUCK
Those measurements are a standard single DIN automotive radio.
You need to find a "XM ready" or "With XM controls" radio and install a separate XM receiver box. For example this would be the in dash deck:  http://www.crutchfield.com/App/Product/Item/Main.aspx?o=p&showAll=N&g=300&i=158XRCA350&tp=5684 And this is the XM receiver: http://www.xm-radio-satellite.com/index.asp?PageAction=VIEWPROD&ProdID=3951
I would suggest finding an in dash receiver that also does HD radio as well as XM.
May 16, 2008 | Car Audio & Video
Xm radio
Egads, I imagine that the electrical system in your car is not properly shielded. You can attempt to locate the unshielded wires and cover them, shield the XM reciever (the interference is most likely within the reviever, not the antenna), or try repositioning the reciever in your car- unless it's in-dash. If it's in-dash, it may be that some of your audio cables aren't properly shielded also.
May 23, 2007 | XM Radio (XMP6000)
Car Audio & Video Logo
156 people viewed this question
Top XM Radio Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
