Question about Linksys Wireless-G WRT54G Router
Dificulty in configuring wrtg4g
Hi
i have mt882 modem. i connecting linksys wrtg4g with my mt882 modem.
i connected one ethernet cable from modem to linksys wrt54g's internet port and one more cable from wrt54g's ethernet port to my pc's ethernet port . i dont know what is the next step to configure in wrt 54g router. plaese help me.
  • 556 Answers
There are three major steps to setting up a wireless router.
First set up WAN side access to the internet. For this you need information about your internet service provider. Please respond with your internet service provider's name or better yet a link to their help/support website.
I assume you already have access to configure the router at 192.168.1.1 if not please do the following. Open Internet explorer and enter 192.168.1.1 where you would enter fixya.com and press enter -- do web pages appear in your screen from the wired computer. If so we have manual access to configure the router. If not let me know.
Please reply with a response to this message.
Second we will test wireless connections to the router
Third we will secure the tested wireless connections to the router.
This process will require interaction and several iterations of instructions to complete. Please add a comment to this request with the necessary information if you with to proceed in this fashion.
Posted on Jan 01, 2008
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
How do you connect 2 routers into one network? I have a Linksys E3000 and a WRT110...I've had the wrt110 for over a year but I found I needed a second router to cover my entire house so I purchased a...
The easiest way is to run a long Ethernet cable from one of the 'LAN' (or 'network') ports on the "first" router to the 'WAN' (or 'Internet') port on the second router. The "first" router is the one connected to your cable-modem or DSL-modem. Both routers will auto-configure themselves for this "wired" connection. Configure the wireless-adapter in the second router as per normal.
Or, run a long Ethernet cable from the cable-modem (or DSL-modem) to a location in the "center" of your home, where you can put your wireless-router, such that its signal spans the entire building.
Or, move the cable-modem (or DSL-modem) to a location in the "center" of your home, and connect the one router at that location.
Dec 15, 2010 | Linksys E3000 Wireless Router
I cannot connnect wirelessly with my linksys e1000 router and was told by their experts that my hp pavilion entertainment pc needed an update for the driver of my wireless adapter. I did go to hp website...
Check the following steps to connect wireless linksys router :
First, you have to connect the router to the ADSL or the cable modem.
Your system has to be set in such a way that it will get its TCP/IP network settings from the router via DHCP.
Second, you need to configure the router to use your Internet service.
Connect the antennas to the Linksys wireless router. Connect an Ethernet cable to the Internet port at the back of the Linksys router and it will establish a connection between your modem and router.
Connect another Ethernet cable between the computer and the router. Then connect the router to an electrical outlet.
Dec 04, 2010 | HP Computers & Internet
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id mehtaankur3@gmail.com
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: yourusername@dataone
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
Sep 15, 2009 | NetGear WGR614 Wireless Router
Connecting to internet
Ok, cable (coax) comes in from wall and attaches to modem. Ethernet cable goes from modem to WAN Port of router. You may have to reboot both devices to ensure that your modem (internet service provider) assigns IP address to your router. If PC is close enough, attach new ethernet cable from one of the 4 ports on your router down to your PC's ethernet adapter. (where your modem used to plug into). Router will now assign an IP address to your PC and you should be able to access the www.
Good Luck and let me know if you have any more questions.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
122 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
