Question about RCA P52960 52" Rear Projection Television
No sound when connected to dvd player
We have an rca rear projection tv model mm52110. when we connect to dvd home theater player there is no sound. it is connected with component video cable.
  • 205 Answers
If it's only connected with component video cable (Red, Blue, Green) cable set then no audio has been connected. You will still need to run a set of audio cables (usually White and Red). The other option is to use Composite cables (Yellow, White, Red). A composite cable set has the video on the yellow cable and the audio on the white and red. Component video breaks the video into the three channels.
I want you to know that I'm not paid for this, I just like trying to help. If I've misunderstood your question or this information does not solve your problem I'd be happy to try to help more. If you do find this information helpful I hope you'll give it a positive rating. Thanks and good luck.
Posted on Jan 01, 2008
How do I connect my Coburn home theater to my Sony 52 inch projection TV I tried but get no sound
if the coburn has a scart interface u willl need a scart cable that terminates to rca the simple av vcr cable jack then ;ug the scart end to the theater and the rca to the tv front jack inputs n u ae ok alternatively get a hdmi cable that terminates to rca and connect the hdmi end to the theater and the rca to the dvi/ dvd/compoment input remember sony use icons not words for there accessories for audio input the icon is an in-arrow to a square box and output an out-arrow from a square box select tv. dvd or component av before u start
Jul 19, 2013 | Televison & Video
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
I have an RCA 52 " projection TV thats now 6 years
you have to run theater system eather through your vcr or your dvd player for mor out put jacks and input jacks on older tvs but the thing is your dvd player remote will be your tv remote the same as your vcr remote.
Feb 13, 2011 | RCA P52937 52" Rear Projection Television
I bought the RCA RTD325W DVD home theater system. The speakers work with the dvd/radio tuner but cannot get them to work with tv. Also have Satellite tv, do I need to connect to something on that? Or is...
Your TV must have a set of Audio Out connections. Connect them to the Aux In on the back of the RTD325W. Then toggle the Line-In/Aux button on the remote until display reads Aux In. System should work.
Sep 08, 2010 | RCA Audio Players & Recorders
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Trying to get surround sound on TV
The Answer is, "it depends". On the back of the disc player, you will find two RCA connections labled "Main R" and "Main L". Connect these via RCA cables to your "Audio Out" R & L RCA connections on the back of your television. If your television doesn't have rear "Audio Out" connections and a menu option to select between internal speakers and external, you won't be able to connect.
Sep 27, 2009 | Protron PDS-2315 Theater System
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
RCA P52960 52" Rear Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
