Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher The lower drawer of my dishwasher does not drain when I use it...I have checked the small drain basket and it is not clogged....I have just sold my home and I am concerned for the next owner. How long is the warranty on these appliances....it came with my unit 2 years ago and I have been the only user. Would it still be under warranty? Thank You Paul
  • 2 more comments
  • randolph59 Mar 24, 2008
    Bosch Dishwasher problem - F signal apperas when attempting to start machine? have cleared exhast but still appears?
  • temey Mar 27, 2008
    water does not drain off
  • freediver Apr 07, 2008
    Residue is recirculating and the drain seems sluggish in the borrom. I cleaned the filter with some lime away but I am still seeing grit on the dishes. HELP
  • osuorange Jan 04, 2009
    My Bosch dishwasher does not drain
  • 126 Answers
Most appliances have a one year parts and labor warranty some are varied or graduated. You can find out in the warranty section of your owners manual or the website of the brand of dishwasher you have you can find user guide /owners manuel there. It is not unusual for some water to remain in the bottom of dish drawers as long as it is not an excessive amount.
Posted on Dec 29, 2008
  • 83 Answers
You have a 3 year warranty on bosch dishwashers
Posted on Jan 02, 2008
  • Glen shaw
    Glen shaw Jan 04, 2008
    im sorry asko has a 3 year warranty my bad
Water still remains in the dishwasher even after cleaning up the drain?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My bosch dishwasher will not drain and makes a humming noise
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Jan 31, 2011 | Bosch SHX4AP05UC Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
Bosch dishwasher not draining
Hi
"Dishwasher not draining" issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Jul 22, 2010 | Bosch Dishwashers
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Water backs up into upper drawer when lower draw is run
make sure hoses arent blocked from bottom drawer. if they not blocked change the check valve in the hose. its under the dishwasher drawer pull the drain hose off the drawer. a small rubber check valve is there
Feb 07, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My GE TRITON XL dishwasher doesn't drain completely when done...no problem while running, but there is always some water in the bottom ....any suggestions>
I've had this problem too, and fixed it by cleaning the lower drain basket. But it could also be your pump or drain hose is clogged. To clean the drain basket, I removed the lower rack and spray arm. To remove the spray arm, turn it counter clockwise while gently lifting it up. There's a lock ring that will also need to be removed. (Remember how these parts come off and in what order.) There is a vertical tube that is attached to the upper and lower spray arms that is secured by a hex-screw that you will need to loosen and disengage from the lower spray arm. After this, you can remove the small protection grid then reach in and clean out the gunk from the basket. I ran a rinse cycle to see if it did the trick and sure enough, it now drains. By the way, I am NOT a professional.
Dec 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Jenn Air Dishwasher won't drain out water. I have checked basket and hose for clog
The problem is most likely that there is a chunk of glass or bone etc. in the small drain pump. this is an easy fix. remove the lower front panel of the dishwasher, you will see the drain line which goes through the cabinet wall into the sink drain and at the lower end is attached to a small pump. Disconnect the hose clamp and the hose by the pump then unscrew the little pump from the frame of the dishwasher so u can look in it. Remove the blockage. Now reassemble everything and u will be back up and running
Apr 28, 2009 | Dishwashers
Bosch dishwasher
1. Check for a clog in the air gap:
That's the silver dome on the back of the sink. Not all homes have an air gap for the dishwasher. (Though it is highly recommended!) Lift off the silver cover. Unscrew or unclip the plastic cap on the top. Look inside. Toothpicks are often found there.
2. Check for debris in the sump by:
Remove the lower rack, the lower spray arm, and screens. Use a #15 Torx bit to remove the cover over the drain pump suction. The hole leading to the drain pump is on the left at the bottom. Remove any debris you find.
3. If you find no debris, you almost certainly need a drain pump. After clearing any clogs, if you hear the drain pump humming, but it doesn't turn, replace the pump.
Comment back if you directions for this.
Mar 12, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
533 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
