Question about Sony PlayStation 2 Slimline Console
Ps2 hookup to lcd tv
How do i hook up my ps2 to my sanyo lcd tv in video 2 with just the red,white & yellow cables?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
I suggest you buy the commponent cable (gold plated) itz better or should i say superior than the AV cable ,you will get the better color ,picture etc.And dont forget to hold "TRIANGLE" & "X" button while the game iz booting (thiz to know if the game support progessive scan or not)..not all PS2 game support progressive scan ,so you may find a few problem like the pixel not smooth ,i guess maybe this PS2 weakness when you play it with LCD .
Posted on Jul 02, 2008
  • 319 Answers
If your sanyo has a video input (yellow) available, and audio inputs available (white and red) then you just need to connect them. Then you need to select the proper input on the TV set. These may be on the back, side, or front of the TV.
Good Luck, and let me know how it worked out!
Posted on Jan 01, 2008
How to hookup Sanyo DVW-6100 to a Sylvania tv
If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
Sep 04, 2014 | Sanyo DVW-6100 DVD Player/VCR
How do you connect a ps2 to the led24916dvdfhd
Well the LCD or TV must have rca..jacks yellow video..red and white is audio..if not u can get a component jack wires for PS2..red.blue..green...video....red and white audio..the TV must have those connections ..for PS2..or get old school cable connected hook ups for PS2..hooks in cable or antenna connecter on TV..UHF connected for ps2
Jul 21, 2014 | Video Game Consoles & Games
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
How do i hookup playstation 2 to vcr with dishnetwork
you dont hook it up to your VCR you normally hook it up to your TV with the 3 colored plugs(Red, Yellow, and White)
Nov 15, 2009 | Sony PlayStation 2 (PS2) Console
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Oct 03, 2008 | Panasonic Televison & Video
Sanyo DS32424 can't hook up PS2
Some of the inputs will be below channel 2. Just channel down below channel 2 and see if it finds them..
Feb 24, 2008 | Sanyo DS31590 31" TV
PS2 hook-up
I would suggest to feed video from another source such as DVD or VCR to the same input, if the video is visible from other sources on your TV; that means the video cable from your PS2 is defective. If you did not see any video from the DVD or VCR nor the PS2, it means that there maybe a loose connection inside the TV on the video input.
Hope this helps.
Jan 03, 2008 | Sanyo DS31590 31" TV
Trying to get ps2 to play on new tv..
USE a VCR between the PS2 and the Sylvania TV.  Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4.  Set the VCR channel to Line 1 or Line 2.  This should work. I hope it helps you.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
370 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
