Question about AVE MFDM104 Car Monitor
AVE AV-1041 - AVE 10.4" TFT Monitor
The picture on the monitor is up side down . how do I fix the problem
Thanks Schortz@netzero.net
  • naz85 Apr 08, 2008
    same here
  • msikes Oct 05, 2008
    Just today, mine flipped all by itself. Cant figure out how to get it back. Any help appreciated.
    New Friend:
  • 3 Answers
Mine is reversed as well and to take it apart and flip or reset?
Posted on Jun 02, 2016
I just took minne apart and changed it myself!
then broke off the top and put it in my dash if you would like to see email me nasiatka85@hotmail.com
Posted on Oct 15, 2008
The picture on the monitor is up side down . how do I fix the problem?
Posted on Oct 14, 2008
Contrl alt andupper arrow at the same time.
Posted on Jul 24, 2008
Have you found out yet i'm having the same problem
Posted on Apr 08, 2008
Not a solution, but I noticed that my remote for my dvd player actually changed the way my picture is displaying. Now I have mine right side up, but reverse. The place where I got it didnt give me a remote for the monitor. I am going to see if they have one. Anyone know where to buy one?
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
I have a Gateway FPD1975W TFT LCD Monitor and the power button is blinking blue. The computer is on but no picture. Need assistance
Hello, it may not be the monitor. It could be that the pc is not talking to it. To check this try another monitor. If it doesnt work on that one,its the computer thats faulty, usually the video card. If however it does work, you have a faulty monitor. They can be fixed or replaced. Or you could try your monitor on another pc, either way you will find out for sure. I hope I have helped.
Mar 28, 2011 | Gateway 19" Widescreen Flat Panel TFT LCD...
All of a sudden there is no picture on my relisys 15" tft monitor, sound and channel change work, please helpnessa, thanks va
The fault is likely the back-light. The fault could be the inverter board that supplies high voltage to the CCFL lamp or the CCFL lamp. The CCFL lamp is a mini fluro tube.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 20, 2009 | Relisys RLT1720 17" LCD Monitor
Re Samsung Monitor
TFT means Thin Film Trangister. You are using LCD (liquid crystal dispaly) this means in lcd monitor use trangister on/off to create a pixel. you should give your monitor to repair at workshop for this problem. i don't know any workshop which located in your city. and about the expence it's all around rs 600 to 1000.
ok
bye
ramesh
Nov 13, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
MONITOR HP L 1940 TFT
I jammed my auto button and the screen now stays on!
Jul 25, 2008 | HP L1940T 19" LCD Monitor
Manual for tv monitor in car
What problem do you have?
atdlee@netzero.com
Mar 07, 2008 | Car Audio & Video
9" FLIP DOWN TFT LCD CAR MONITOR DVD OVERHEAD TV
No problem.
The size will not be the same.
Ask for the size, you wants the same or a larger size.
atdlee@netzero.com
Mar 05, 2008 | XO Vision GX733 7.3 in. Car Monitor
Xovision monitor
To what car?
Black wire to ground.
Red wire to +12VDC.
Yellow cable to input of Yellow Input's radio.
atdlee@netzero.com
Dec 21, 2007 | XO Vision 12.1 Flip-Down Monitor w IR"
AVE MFDM104 Car Monitor Logo
733 people viewed this question
Top AVE Car Audio & Video Experts
xxxxxx xxx
Are you an AVE Car Audio and Video Expert? Answer questions, earn points and help others
