My model AZ22E15 zoneline AC unit is not coming on. There is no voltage from transformer to control board regulator: Are the transformer specs: 240 VAC in, 24 VAC out @ 40VA?
air worked fine all last night and this morning. Now I cut thermostat on and unit come on for a...
(More)
air worked fine all last night and this morning. Now I cut thermostat on and unit come on for a minute then shut off
Have a mistral air con, inside unit comes on but not the main unit outside, is there a fuse in the...
(More)
Have a mistral air con, inside unit comes on but not the main unit outside, is there a fuse in the outside unit, the unit came on during a storm and now not working. Thanks Roger
we installed a msg18 mini split system h/p, tied in tubing, pulled good vacuum , wired 230v. to...
(More)
we installed a msg18 mini split system h/p, tied in tubing, pulled good vacuum , wired 230v. to condensing unit then wired 230v.and one low voltage s wire from cond. to blower section , released 410a freon. blower and remote is upstairs, system will startup then lockout before getting down to cond. defrost board is blinking 5 times. ( why )!! ?
