Question about Frigidaire FEF336BC Electric Kitchen Range
Fridgidaire Gallery Model#CFES387CFS6
The little L latch meant to hold the oven shut while self cleaning is stuck to the right and now the door is locked with the oven door open.
Already tried to cut the power to the unit via the breaker thinkin it would reset to no avail.
Girlfriends folks coming in two days.
  • 1 more comment
  • hertel345 Sep 17, 2008
    codes error F1 and F3
  • ha_ha2kute Feb 17, 2009
    my oven is stuck on lock when i push the buttons i get a f90 help please
  • Anonymous Mar 31, 2014
    clean lock stuck closed code9
Tech17 posted the reply in december that worked for my oven w/same problem. hold in door button and pust cancel and it will reset after about 5 - 10 secs
Posted on Jan 19, 2008
Self clean and oven light
The latch is stuck halfway! Take your finger and push the latch all the way to the right until the oven light goes out. Now hold it there and press the self clean button. Let it start up for a few seconds then hit the off/cancel button and let go of the latch. It should hear it made a winding like sound as it goes back to it starting position.
Feb 10, 2014 | KitchenAid KGSK901SSS Gas Range
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
How do I self clean my gallery series fridgidaire?
Some of the self cleaning ranges require that the door be locked before the self-cleaning cycle will work. If your oven door has a manual locking lever then make sure it is completely latchedthen press the self-clean button. Also make sure the dooris completely closed because if there is not a manual latch then it will be a auto latching system. If not then there could be a problem with the button on the control panel for the self cleaning option.
Jan 14, 2010 | Kitchen Ranges
F90 code on Fridgidaire range/oven
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
-F9- Clean Frididaire Gallery Series
F9 code means Control has detected a problem with the motor door latch assembly Soultion: Check wiring, replace the motor door latch assembly if necessary
May 06, 2009 | Frigidaire 30 in. Electric Gallery Series...
Message says "unlock door", but the door is already unlocked.
redo the self clean, something got stuck... also, dont use the selfclean again, use easy off overnight, self cleaning sucks and uses lots of $$$$$$$.
Feb 13, 2009 | Kenmore 75620 / 75621 / 75622 / 75624 Gas...
Oven door will not close because the door lock is on and flashing, also the oven light won't go off. how do I fix the door lock flashing so I can close the oven door completly?
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 03, 2008 | Ovens
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Nov 25, 2007 | GE JGB916SEKSS stainless steel Gas Kitchen...
Frigidaire FEF336BC Electric Kitchen Range Logo
434 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
