Seiko Divers Automatic watch Logo
Anonymous Posted on Oct 27, 2009
Runs slow by 60 seconds a day. day/date also turn a few hours late
Anonymous
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on Nov 03, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
93
Questions
0
Helped
51120
Points
149
Your watch is in need of service. Running slow is an indication the oils have dried out and are not lubricating any more. When oil dries it gets sticky like a soft glue. A mechanical watch can have the power to force the gear train to run but the constant drag on the dried out thick oils will cause it to run slow.
All watches should be serviced regularly.
The date issue is due to the hands not being installed properly. This is an issue that will be taken care of when the watch is serviced.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Testimonial: "Great advise, Thanx. Eli"
  • Anonymous Nov 11, 2009
    Hi Eli,
    Glad I could help.
    Ken Kotoski
13 days is how many hours,minutes en seconds?
There are 24 hours in a day, 60 minutes in an hour, 60 seconds in a minute, so there are:
24 hours per day
24* 60 = 1,440 minutes per day
1440 * 60 = 86,400 seconds per day
13 days = 312 hours 0 minutes 0 seconds
or
13 days = 18,720 minutes 0 seconds
or
13 days = 1,123,200 seconds
Jul 18, 2014 • Watches
1helpful
2answers
Date changes at mid day not at mid night.
Your watch is 12 hours out of step.The date changes ever second rotation of the hour hand.
If you advance the time 12 hours, the date will change at midnight.
You may have to re-set the date.
The date on my Tissot PRC 100 changes either 1/2 day early or 1/2 day late. How can it be set so that the date changes at 12:00 am?
Your watch is 12 hours out, as it "thinks" that midnight is midday.
The solution is to wind your watch forward 12 hours and then the date will change at midnight.
3answers
The day inscription is two days late, monday, watch says saturday
So to change the Day and Date of your Watch, slowly pull the Stem out... (Do note that if you have a Waterproof Watch, you'll need to unscrew the Stem counter-clockwise, which is towards you, until it unlocks, then you can pull the Stem out!) But this is where you need to go slow. If you pull it out slowly you should hear one snap. (It stops on the first notch) If you pull the Stem out all the way, it snaps twice and ends up on the second notch. (See picture below) The second notch, or all the way out, is where the Stem needs to be to set the Time.
day-changed.gif But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date!
Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch!
If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle.
Jun 27, 2011 • Watches
1helpful
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
How do you set the day/date on a watch????????
Try this solution I posted earlier for a similar problem.
Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time.
If you pass 12:00 and there's no change continue rotating another 12 hours (to twelve o'clock again) and they should advance. Once you've found that there's midnight.So say it's now 4:00pm you would need to rotate the hands around the dial again so they pass 12:00 once more (12:00 midday) then four hours more to 4:00.
To set the day/date you can set the crown (winder) to the first position (second posn is "set hands) and rotate winder
eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
Hope this solves your problem.
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
2answers
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Cascio
To sync the correct 12 hour with your day you need to set the date to the day before (if today is 21, then make sure the day window reads 20). Then spin the analog hands until the the date window turns to 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm.
That's how you do it. If you need more clarification let me know.
Top Seiko Watches Experts
Paul Bade
Ngoro
Are you a Seiko Watch Expert? Answer questions, earn points and help others
