Question about Kitchen Ranges
Frigidaire deluxe electric stove Model# RDG3-35S
The clock does not work and I cannot find the fuse to check if that is the problem. Also under the right burner, there is a pipe that comes up from the oven. There is no cover and I can look in and see the oven light. Needless to say, the stove top gets hot when baking. I got this stove used, but did find a owners manual. Neither of these problems show up in the owners manual.
I would greatly appreciate any help.
sky60
The pipe is a vent pipe it is normal and th fuse is behind the back panel right behind the pots and pan shelf beside the stove pull the shelf out and replace the fuse with a 15 amp
Posted on Oct 05, 2011
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
My burners work on the stove but the clock, and over buttons will not come on, so I'm unable to turn on the oven. I have a Frigidaire model FEF366EMC
Check for a blown thermal fuse protector. Located on the back wall of the oven behind a sheet metal cover. Disconnect power and you can ohm it out.
Jun 27, 2010 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
My oven and stove top in inoperative. the clock,
If everything checks out fine, and you have no wires grounding out, then the issue is the control or circuit board( same thing).
Jan 02, 2010 | Frigidaire FEF366 Electric Kitchen Range
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Dec 28, 2017 | Frigidaire FEB27S5A Electric Single Oven
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
FRigidare new stove installation
Loud pop means electrical fault occured. There may be and internal fuse in the oven that blew. Probably blown oven element but certainly open circuit to timer. Remove back, check for supply to oven timer. If supply is there, the timer can be bypassed to allow for oven element to work as clock replacements are very expensive.
Nov 09, 2008 | Frigidaire FEF355 Electric Kitchen Range
Kitchen Ranges Logo
584 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
