Question about Video Game Consoles & Games
2 problems with Ps2
1 - Well, The play station two's disc tray sometimes sticks, and doesn't come out. sometimes it does. What would cause it to just stick like that?
and
2 -
Game: Sly 2: Band of Thieves
Percentage - 99%
Episode not complete - Ep #7
Clues - 30/30
Problem? -
It constantly freezes in Episode #7and when I go through a door to findthe vault it keeps loading and loading and loading.. And never doesanything but shows the pulsating coon-face icon on a black background! PLEASE HELP!
  • 1 more comment
  • Sub Zero
    Sub Zero Jan 04, 2008
    Thanks for helpin'. I may try that. :D
  • Sub Zero
    Sub Zero Jan 07, 2008
    CRUD. That suggestion made my ps2 go boom. ;___;
  • Anonymous Mar 29, 2014
    cannot find this episode,"it takes two."
  • 41 Answers
Go inside your ps2 and dust it you heard me just dust it from the inside trust me this always works use a small cotton ball and dust the ps2 everything is going to work better no more slamming the ps2 on to your bed!being all angry i though mine broke but i went inside it for the heck of it and decided to clean it to see better then all of the suddeni made a sound i was freked i fin. cleaning it put it back together and bam good as new no freezes no pulling on the sony emblem to get the disk back! good as new!
comment me please
Posted on Jan 03, 2008
I moved my xbox360 while disk spinning in it,the current game doesn't work so good anymore,and now it makes tick-tick noises sometimes when game disks are playing.It reads all disks,theres no problem...
The users manual for the xbox 360 says to never move the console with a game inside. In doing so, you probably knocked the disc off the spindle causing it to grind against the laser and laser assembly. The ticking noise is probably from the motor that moves the laser back and forth across the disc. A spring may have come loose from the motor causing it to click as the screw occasionally slips from the guides. This should not cause a problem, however the plastic inside the motor may wear out causing the "open tray" error after some time in which case a repair will be necessary.
Oct 03, 2011 | Microsoft Xbox 360 Console
I put in a blu ray disc but it is not playing in any media player and the disc drives do not recognise that a disc has been entered
Unless the drive in your laptop is a blu-ray drive, it won't recognize a blu-ray disc. A blu-ray drive can recognize and play a regular DVD, but it doesn't work the other way around.
If your computer is indeed fitted with a blu-ray drive, the laser lens may need cleaning. On a laptop, you usually have clear access to the lens with the tray open, so you can try cleaning it with a cotton swab moistened with lens cleaner. Or the disc itself may have a problem. Try another disc and see if the trouble continues.
If the computer doesn't have a blu-ray drive and you will frequently want to play blu-ray discs, get a USB external blu-ray drive. It's easier to find one of those than to locate a suitable blu-ray replacement drive for a laptop. There are many variations of drives used in laptops, but an external drive will always be compatible. And you'll be able to use it with other computers not blu-ray equipped.
Apr 23, 2011 | Acer Computers & Internet
Why wont my xbox 360 elite read discs? i put disc in and it comes up reading and then open tray
My only questions are does the console say the discs are damaged in any way? and is the console standing up right?
If the discs are scratched in any way then that might cause the 360 to not read the disc and sometimes having a console play the disc upright (example of upright 360) for a long time can cause dis function when trying to play discs, so try playing the discs with the console on its side (side example) These are my solutions to the problem but you can try these: Solution 1 Solution 2
Mar 13, 2011 | Microsoft Xbox 360 Elite Console
Play station 3 not reading disc
Hi
ps3 can read only original discs
the one you have probably is a copy
Jan 08, 2011 | Sony Playstation 3 (PS3) Console
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Reads the games but only says close tray and open tray
It sounds like you will need a drvie replacement or motor. Sometimes the magnetic disc on the motor comes loose and it sticks to the top of the dvd drive cover and causes it to not function. We can fix this for you if your interested email us.
xbox360fixer@verizon.net
Jan 11, 2009 | Microsoft Xbox 360 Console
Disc Tray will not close
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Aug 10, 2008 | Samsung HT-X50 System
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Video Game Consoles & Games Logo
69 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
