Question about Protron PLTV-32 Television
Looks like a water stain on screen
I have a 32" protron lcd tv. All of a sudden it has what looks like a water stain down the side of the screen. Any ideas what this could be and how to repair it?
  • 2 more comments
  • lucky40 Jan 04, 2008
    I have a samsung LCD tv and our son dropped a milk drink which splashed onto the screen - someone tried to wipe it with water, so now there's several marks on it. The picture quality doesn't appear affected, so it's only obvious when the TV is off. A few questions: how do we clean it? Is it permanently damaged?
  • kellejay Jan 07, 2008
    Have the same thing on mine. Have not spilled anything on it.
  • Anonymous Dec 11, 2008
    i have a protron 37 inch LCD with the same problem. I would like to know how to fix it if there is a way I has way greenish stais that sow up more with lighter background
  • Anonymous Mar 08, 2009
    CAN WATER STAINS BE REMOVED FROM TV MY CHILD WROTE ON IT WITH A CRAYRON AND TRIED TO GET IT OFF WITH A WET TOWEL
IT SHOULD NOT NEED A "REPAIR" PER SAY. HOWEVER, I OWN AN LCD TV, BUT NOT A PROTRON. YOU'RE GONNA FIND THIS PROBLEM WITH ALL LCD TV'S. IT SOUNDS LIKE IT IS SIMPLY DIRTY. THIS IS THE WAY YOU CLEAN YOUR SCREEN. IT IS VERY EASY AND FAST, AND YOU SHOULD HAVE THE SOLUTION IN YOUR KITCHEN AND BATHROOM. TAKE THE CLEANEST, MOST SOFT CLOTH YOU HAVE IN YOUR HOUSE. DAMPEN,NOT SOAK IT, WITH WATER, AND LIGHTLY RUB A SMALL SECTION OF THIS STAIN, AND SEE WHAT HAPPENS. IF THIS DOES NOT WORK, ADD A SMALL AMOUNT OF SIMPLE RUBBING ALCOHOL, AND TRY ANOTHER SMALL SPOT OF THE STAIN. IT SHOULD COME OFF. SOME OF MY "HI-TECH" FRIENDS USE STRAIGHT RUBBING ALCOHOL, AS IT HAS A TENDENCY TO EVAPORATE A LOT FASTER THAN WATER AND LESS LIKELY TO LEAVE ANY "WATER STAINS". HOWEVER, IF YOU CANNOT SEE THROUGH THIS STAIN, THEN YOU'RE BETTER OFF BUYING A NEW TV. SOUNDS LIKE SOME KIND OF LEAK OR MAYBE THE TV IS JUST NEVER SHUT OFF, THEREFORE BURNING IMAGES INTO THE SCREEN. FORTUNATELY, IF IT IS STILL UNDER WARRANTY, YOU MAY GET HELP THERE. MY FIANCE TOUCHED THE LCD SCREEN WITH HIS FINGERS, AND IF YOUR FINGERS ARE DIRTY, THEY WILL LEAVE OIL STAINS. PEOPLE DO SOMETHING TO A PRIZE POSSESSION IN YOUR HOUSE, DONT TELL YOU THEN ACT LIKE THEY DONT KNOW WHAT HAPPENED. ITS HILARIOUS. HOPEFULLY THE ISSUE YOU HAVE CAN BE FIXED BY YOU!
Posted on Jan 08, 2008
Tip
Protron PLTV-32 Manual Download
Download Spectroniq Protron PLTV-32 LCD TV Manual
Would you like to review the features of the Spectroniq Protron PLTV-32 LCD TV ?
Have you lost your Spectroniq Protron PLTV-32 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the Spectroniq Protron PLTV-32 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Spectroniq Protron PLTV-32 LCD TV documentation.
I hope that helps.
___________________________________________
Protron PLTV-32 Service Manual Download
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | Protron PLTV-32 Television
Tv wont turn on
outlet power and fuse check them . don't forget that if you want to replce fuse , you have to replace with a fuse with same rating
Sep 15, 2009 | Protron PLTV3250 32 in. LCD Television
We need a ACPower Adapter# for Protron PLTV-32 LU32A143 LCD TV(not EBay)
If I where you, I would just go to hardware store and get multi-adapter for $10 and make your own
May 20, 2009 | Protron PLTV3250 32 in. LCD Television
Tip
I hope that helps.
on Jul 05, 2010 | Spectroniq Protron PLTV-32 32 in. Plasma...
Wire on tv screen
it is a simple job to fix that. you need to take the whole TV apart and there is a black gasket that falls down on all these TV's. the glue that was on the gasket and the weight of the screen pulls it down more and more. takes about 1 hour by an amateur doing this maybe less for a professional.
Jun 02, 2008 | Protron PLTV-32 Television
MOTH
I'm guessing you have a matt finish to your screen in which case it is semi flexible plastic. It's important not to use anything abrasive or acidic as it could leave an etched mark. The best think is to soak a tissue in a solution of bicarbonate of soda and warm water (about 1 teaspoon to 1/4 pint water), then with your TV switched off, tape the tissue over the stain and leave overnight. Gently rub the tissue over the area the next morning and the mark should have gone or at least be less noticeable. Hope that helps :o)
Jan 27, 2008 | Protron PLTV-32 Television
Staining on LCD tv screen
The LCD screen is bad this may have been caused by presure exerted to the screen fracturing the cells of the LCD. any way the LCD is bad and needs replacing.
Dec 27, 2007 | Philips 32PT6441/37 32" TV
Protron PLTV-32 Television Logo
3,599 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
