Question about Janome 8080 Computerized Sewing Machine
Janome 8080 needle threader
Where can I buy a replacement for the needle threader?
The needle threader on my Janome 6260 quit working. The needle is inserted correctly.
Is the threader broken or just not meeting the needle eye? If broken, it can most likely be repaired.
If the threader is not meeting the needle eye, adjust the needle height so the threader meets the eye and intercept the thread. I have a 60's machine with a threader that needs the needle height manually adjusted because the needle does not stop in any particular place. Usually, if I raise the needle to its highest, the threader will work.
Oct 06, 2016 | Janome Sewing Machines
Finding equivalent
I can't seem to find a decent picture of the Kenmore 385.16120200, but from the replacement parts that I can see, it may be close to this one:
http://content.janome.com/index.cfm/Machines/Sewing-Quilting/2212
Or maybe:
http://content.janome.com/index.cfm/Machines/Sewing-Quilting/Magnolia_7318
Janome is an excellent brand, and any Kenmore built by Janome is going to be just as good, but a little less expensive. However as the Kenmore sewing machine line seems to be hard to find even used, and if you are considering buying a Janome, I would highly recommend a few features to you:
Drop-in Bobbin, One-step Buttonhole, Automatic Needle Threader, and maybe (depending on your tastes and preferences) a few electronic features like Needle Up-down and Push Button Stitch Selection. If at all possible, go into a shop and try before you buy. Hope you find what you are looking for!
May 04, 2014 | Kenmore Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Janome 1860 needle threader
If the hook is bent, you might be able to straighten it, but I would go to my dealer and purchase a new threader. It is much easier to replace it.
Feb 06, 2012 | Janome Sewing Machines
How can i replace the threader, mine seems to be broken. When I want to thread it does not catch on the needle.
Perhaps the little hook has been damaged on the end?
I have seen this part
http://www.sewingpartsonline.com/needle-threader-elna-janome-new-home-755643002.aspx
listed for sale - it doesn't list your model but it looks very similar to the threader on my Janome MC6500.
Mar 12, 2011 | Elna Quilter's Dream 6003Q
After I broke a needle the threader won't thread the new needle. Does it only work with Janome needles or is something out of alignment?
Threaders only work with certain combinations of needle and threads. Too small an eye or too big a thread and its a no go. The book should give an idea of the combos you can do. Make sure the needle is inserted completerly up inside that needle clamp.
Jan 17, 2011 | Janome Memory Craft 9000 Computerized...
Broken prong on built in threader
You won't even look at my problem unless I pay you money but you want me to tell you, for free, how I fixed the problem? Doesn't seem fair to me. I will post my solution on a free forum. Sorry to all you folks looking for the solution.
Jun 22, 2009 | Janome 2049LX Mechanical Sewing Machine
Kenmore 19606 Auto Threader
I have this machine also. Make sure your needle has been placed the right way around w/flat of back needle to back entry port. Also raise the needle up to the highest point it will go, sometime the alighmnet is off and if this doesn't work then you may need a service call.This machine is made by Janome for Kenmore, so most Janome parts will fit yours too.
Feb 22, 2009 | Kenmore 19606 Computerized Sewing Machine
Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Feb 12, 2009 | Janome Memory Craft 9000 Computerized...
Janome 8080 Computerized Sewing Machine Logo
252 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
