Home | Hoover | SteamVac Carpet/Upholstery Deep Cleaner Vac... | I poured the water out...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Problem for Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
I poured the water out and when i went to put lid
By aprillovegre on Oct 27, 2009
i poured the water out and when i went to put lid back on its not sucking up the water and lid keeps moving around
Solution #1
posted on Nov 15, 2009
Not Rated)
rmoore5
Rank: Apprentice
Rating: 0%, 0 votes
I have seen these recovery tanks put back after emptying and not correctly in place. Check to see if the tank is completely in place and the hooks on the lever are engaged correctly.
Was this helpful?
Yes
No
Solution #2
posted on Oct 28, 2009
Not Rated)
elextek
Rank: Guru  Vacuums  Expert
Rating: 86%, 117 votes
The lid on the lower tank needs to have a tight seal, otherwise you will lose suction to the floor. make sure all latches are secure.
Was this helpful?
Yes
No
Popular Solutions for Hoover SteamVac
Questions and Unsolved Problems for Hoover SteamVac
Do you recommend Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum?
Answer
Answer
Brushes on Hoover Steam Vac F7441-980 do not turn.Brush control on;drive pin present;filter intake... (More)
Answer
the upholstery attachment won't slide down to meet the opening for suction. Don't know how to attach... (More)
Answer
How do I take it apart to clean it - hover model f6213-900
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover SteamVac...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 892
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
