do a test print... see you manual. You hold a button for 3 seonds and it'll print a test page. If that works you should be OK. Make sure that your paper tray is NOT over loaded. Maybe try less paper.
Try the manual feed using one sheet of paper
paper tray level indicator shows less that actual level and the paper low indicatioon when there is...
(More)
paper tray level indicator shows less that actual level and the paper low indicatioon when there is paper still in the tray.
I have a Brother HL-5250DN Laser Printer and when I send the signal to print, it starts making...
(More)
I have a Brother HL-5250DN Laser Printer and when I send the signal to print, it starts making noises what can I do?
I changed my HL-5250DN from local USB to Ethernet on my DI-604 router. I cannot print from...
(More)
I changed my HL-5250DN from local USB to Ethernet on my DI-604 router. I cannot print from Wordperfect X4, SP2. I receive this msg. "The document page is set to a paper size (letter) that is not supported by thid printer driver. Do you want to match to the closest printer defined paper size (Organizer M)?" I have reloaded Word perfect and the drivers from the Printer CD. Each made no change. I can print from any text editor and from MS Word 2003. Can you help me please? Thank you Jamie Jamieson 1woodshaper2@gmail.com
