Question about Dryers
Thermal switch location
Where is the thermal fuse located for the lower portion of a Maytag MCG8000A dryer?
    President:
  • 878 Answers
On a series 10, it's located behind the bulk head, behind the drum. On a series 11 they moved it to a bracket on the heater cone. Catriver.
Posted on Jan 01, 2008
  • Ron Marek
    Ron Marek Jan 01, 2008
    Your serial number will tell you which series, first 2 digits.
Locate thermal fuse on maytag neptune dryer model # mlg2000aww
The thermal fuse is located on the front cover over the blower wheel housing in the front of the dryer, the part # is 33001762,good luck
Aug 24, 2015 | Maytag Dryers
No heat gas dryer
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. In some cases the ignitor or the gas coils will go bad. Here is a good process of elimination.
1)Verify that the thermal fuse is good. If you don't have a meter bypass it and turn the machine on. If heats, thermal fuse is bad, if not leave connected and continue
2)When the dryer starts and thermal fuse bypassed, the ignitor should start to get hot and glow, if your thermal fuse is in the back you are going to have to have to the top of the dryer up to see down inside near the front for the glow. You can do this by taking the lint trap out and removing the two screws and popping the top up. If the ignitor comes on more than likely the gas coils are bad and if it doesn't the ignitior is bad. (this is while the thermal fuse is bypassed so the ignitor has power to it regardless)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 29, 2012 | Maytag Dryers
How do you replace thermal fuse
May 14, 2012 | Kenmore 700 6972 Dryer
Maytag gas dryer bravos mod#MGD6400TB0 no heat
May 11, 2012 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Apr 29, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How to replace the thermal fuse in lgq8611lw1
The thermal fuse is bad, the part # is 3392519. This part is located at the back of the machine on the lower left side. You will need to remove the back panel to access this part. Be sure that you unplug the machine before starting. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer.
Apr 27, 2012 | Whirlpool LER4634J Electric Dryer
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
488 people viewed this question
Top Dryers Experts
Marvin
Marvin
