Question about Denon AVR-3806 Receiver
Unable to select function (vcr-1, dvd, tv etc) from remote
My son was playing with the remote, and now I am unable to select functions from my remote. What might be the problem ?
  • 98 Answers
I think u have loose parts in ur remote...if you know how to solder check for loose parts ok...
rate me fixed ok
Posted on Feb 14, 2008
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
Im trying to program a remote the tv is a zenith
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
then release SET.
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Direct tv remote will not operate my tv cannot find proper code
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV.
2. Slide the MODE switch to TV.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV press CHAN+. Repeatedly press CHAN+ until the TV turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Solution found at: http://2getdtv.com/directv/remote_codes.html
Hope this helps.
Mar 05, 2010 | Televison & Video
My olevia tv and Ge Remote control wont work lost code. Help?
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
LIGHT lights, then release.
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
button you are assigning to AUX.
Feb 01, 2010 | GE JASRM24912 Remote Control
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
When I press the TV/VCR button on the remote, the picture on the TV becomes fuzzy and we see no signal from the DVD player. The first sign we were having trouble was that we couldn't set the time...
The TV/VCR button is usually not a function of a DVD player itself.
Normally this is a button on VCR remote controls that allow you to switch between whats playing in the VCR or whats coming in from the 'air/cable signal' from the cable or antenna wire on the back.
If this is a VCR/DVD player combo unit it would appear that the TV may be on the wrong channel for proper operation of the VCR functions (ch 3 or 4 are usually the selectable option on the back of the unit).
Make sure your DVD player is plugged into the correct input on the TV(video 1/svideo/or component ) and the TV is tuned to that same input. If the TV is on the correct input then the TV/VCR button shouldn't do anything at all which is normal operation when watching a DVD. If this doesn't clarify please reply with the model # of the unit. I would be happy to help more.
Aug 05, 2009 | Panasonic Televison & Video
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Denon AVR-3806 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
