Question about Tefal UltraGlide plus 1656 Iron
Iron hi, when i iron bits come out onto the clothes what do i do?
  • Anonymous Sep 30, 2008
    when i iron when it steams dirty water comes out of iron, but only from the last two or three holes at the bottom of row of holes.
    i have a water softener so my water is soft but should i stil filter it????
Thats probably from the minerals in the iron?
try using distilled water with a low content in minerals.
or try to make sure there is no water left (use the vapour function) before you store it for next time.
Thats my 2 cents. Hope it helps!
R.
Posted on Jan 03, 2008
6ya staff
SOURCE:
I just bought this iron in March 2015. The iron leaks water all of my clothes when I press the steam button. I have it set on the highest setting for iron and steam.
Increasing the temperature setting can ease this issue, however it is important to consider the type of fabric you are ironing.
1st option: Fill the iron up, and let the iron stand as the iron heats for little while before using. This may allow more of the water to be converted to steam.
2nd option: You could try using deionised/distilled water in your iron.
If you find that the water leaks out sporadically, it may be worth pushing the steam button once or twice before applying it to clothing.
I have attached a link with a little bit more information How to Stop Steam Iron From Dripping
Apr 30, 2015 | Irons
Its giving my clothes black marks
It is to hot. read the labels in your clothing, what temp you are allowed to use and dial that in on the iron. Still burn marks, bring it back, because then the thermostat s not good.
Feb 05, 2015 | Tefal Irons
How do i stop water dripping onto my clothes
ensure that your iron temprature is high enough to generate steam. if ironing delicate cloth ensure your steam option is switched off. if your iron has a filler cap or water container ensure they are fitted securely. water dripping usually when the iron is too cold to turn it to steam or you have a leak somwhere.
May 21, 2014 | Irons
Tefal steam iron cleaning
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 24, 2010 | Tefal UltraGlide Easycord FV4256 Iron
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
How do I clean my iron? The iron part on outside
Here is a tip that will help you with cleaning the bottom of your iron...
heatman101
Apr 05, 2010 | Black & Decker Steam Xpress AS250 Iron...
Digital revolution iron squirts brown water onto my clothes
Try an iron cleaning fluid or crystals. you can get the stuff at wallmart or similar stores. It usually works. Try using distilled water in the iron.
Jul 27, 2009 | Irons
Tefal UltraGlide plus 1656 Iron Logo
147 people viewed this question
Top Tefal Irons Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Norman Worley
Are you a Tefal Iron Expert? Answer questions, earn points and help others
