KitchenAid 325 Watts K5SS Heavy Duty Commercial Stand Mixer
Problem for KitchenAid 325 Watts K5SS Heavy Duty Commercial Stand...
My KitchenAid mixer does not turn off. I'm sure
By bam623 on Oct 27, 2009
My KitchenAid mixer does not turn off. I'm sure it has something to do with the switch which does not stay in the off position. Who can I get to fix this?
Clarification Request
Posted by co7196 on Oct 28, 2009
If you cannot locate a replacement switch, Recommended. that you do. Is this switch the tail end of the head that rotates for different speeds? This is a commercial grade unit and should be repairable.. Type Kitchenaide in the search bar and locate a service center. You can probably get the parts from them or have them repair it. Worse case scenario, you can put a cord switch in the cord. Not a cheap one
Popular Solutions for KitchenAid 325 Watts K5SS
Questions and Unsolved Problems for KitchenAid 325 Watts K5SS
Do you recommend KitchenAid 325 Watts K5SS Heavy Duty Commercial Stand Mixer?
Answer
Answer
I am having problems with my k5ss kitchenaid mixer. The problem happens when i tryed to even mix... (More)
Answer
KEHC309JSS05 door shows open. indicator says ''close door''. The door IS closed. New oven, been in... (More)
Answer
K5A 30 year old mixer will only operate at lowest five speeds. stays at speed 5 as control is moved... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Mixers Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
