Question about Polaroid FDM-1000A 10" Under-the-Cabinet LCD TV with DVD Player Television
DVD malfunction- won't read or eject
This unit worked fine until all of a sudden it would not read or eject a disk, even after power plug was pulled and reconnected.  After opening the top and manually removing the disk, it would still not eject or power up.  After placing a different disk into the unit through the top, it would still not read it. Meanwhile, the TV and radio functions are working perfectly.  I don't see any signs of power arriving at the DVD laser or eject mechanism.
 How can I tell if it is the power cable to the DVD unit that is not functioning?  Can this be replaced or does the whole DVD unit need to be evaluated?
Lee Learman:  email me at
0 characters
1 Points
How to remove a dvd when no power to tv?
If not already done so, check the instruction manual (on-line if you don't have a copy) to see if there is anything about this in the troubleshooting guide - it may have a key combination on the remote or similar to force eject the disk. Failing this, if you can open the outer flap of the disk drawer without forcing it, you may find a small reset hole which can eject the disk manually by using something like a straightened paper clip to put into the hole and press the recessed button that is accessible via the hole. It can be a little difficult to find as depending on the design of the TV, it can be obscured behind the plastic of the TV body. Don't be tempted to force the disk drawer out as this can knacker the mechanism completely. BTW, if the disk is not a pre-recorded disk, (recorded yourself), this can cause an error like this - powering everything off and then pressing and holding the eject button as you power up may result in an eject. Hope it helps!
Feb 24, 2015 | Naxa Ntd-1952 19" Widescreen Hd Led 1080p...
SDP95SWN does not recognize any disc
Either a dirty or a bad optical pickup in the unit.
May 28, 2012 | Toshiba portable dvd player SDP95SWN User...
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
Jul 08, 2011 | RCA Portable Televisions
I place the dvd in the holder, and it closes, but does not play. It says loading and then nothing. please help.
Tries the tv DVD player,play it with many other DVD discs too?Some the disc u trying to play it might just be bad like the reading shinning laser surfaces are scratches,smushes or grims and dirts on the disc reading surfaces?Tries washes the DVD disc,with some dish washing liquid,dries it with a cloth wait like two mins.Try the DVD disc again.If it have problems,but all DVD discs or with many other DVD discs too?Tries websites like or buy a Disc cleaning kit put Disc in the DVD player to play it have 50/50 chances to clean the DVD player laser eye reader.If not more like the DVD player laser eye it is dead.Tv still work fine?Don't take the tv aparts,tries to clean it laser eye manally,because,if u putting tv back together again might causes tv problems too.Just buy a DVD player unit plug it in the tv and play ur DVD Discs.DVD player extenal unit it very cheap these day.Don't take chances,like take ur tv aparts.
Feb 12, 2011 | Naxa Electronics NX-542 13 in. Portable TV
I have a Memorex MVUC821 8" TFT DVD Player. Upon power on, the red standby light turn green. The unit checks to see if a dvd is the player and then cycles the dvd player since not disk is present...
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like ""(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Compliments of the season.
Dec 29, 2010 | Memorex MVUC821 8 in. Under Cabinet TV
DVD player not accepting dvds
Contact the helpline on 0871 2000 463. Maybe a faulty DVD drive. (Try a few different original disks first)
Feb 19, 2009 | Tvone TV-207 Television
Unit is completely dead
Is the adapter getting hot ,then you replace the adapter else you can check the o/p of the adapter with help of multimeter it read 12 volts ,if it reads 12 then there is problem with tv itself..
Good luck...
Feb 02, 2009 | Polaroid FCM-0700A 7 in. Portable...
26" 720p HDTV/DVD COMBO will not eject disk
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope it may help you;
Jan 29, 2009 | Polaroid FDM-1000A 10" Under-the-Cabinet...
Hard to get dvd player to work
How old is the set? As the player's laser ages it becomes harder for it to read discs. Audio CD's don't have as much data and are formatted differently from DVD's so they are easier to read. This is one possible cause. Hope this helps!
Nov 16, 2008 | Naxa Electronics NAXA NX-571 Television
Under counter audiovox tv
You can try to unplug it then plug it in and try eject. If that don't work the it will have to be disasembled to remove the disk. it could be that the disk is not spinning up and in that case it will have to be repaired
Feb 11, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Polaroid FDM-1000A 10" Under-the-Cabinet LCD TV with DVD Player Television Logo
Top Polaroid Portable Televisions Experts
Are you a Polaroid Portable Television Expert? Answer questions, earn points and help others
