Philips GoGear 2GB memory corruption
Hi, We purchased a Philips GoGear Ipod and a couple days later this poped-up. we did the repair and there is no change. WHAT TO DO ? HELP!!!!!
  • 4 more comments
  • aristacat Mar 13, 2008
    i downloaded music on my go gera phillips mp3 and every time i turn it on it says memory corruption repair now. how do i fix that?
  • Anonymous Mar 22, 2008
    when i turn on my philips mp3 it says memory corruption. then it says press ok and the problem will be solved but when i press ok it turns off
  • dmiller123 Apr 03, 2008
    when i turn on the mp3 memory corruption will com on and when i press ok it will repair and turn off
  • Anonymous May 01, 2008
    i have the same problem as these people when i turn it on it says mwmoey corruption repair now and when i do it repairs it then shuts off i can do this for hours and it dose the same thing how do i fix it?
  • demonteporte Oct 11, 2008
  • Anonymous Apr 02, 2009
    I deleted everything on my go gear and its still saying i need to free up space!
I have the same problem , my friend works on them said some how the info on the hard drive got ereased. maybe i had i to close to big speakers .
Posted on Aug 20, 2008
Earase every thing and it might work one of my frinds did and does that when it happens so try it
Posted on Oct 12, 2008
My philips ipod gogear 2gb showing I/O device to solve this
my philips gogear vibe 2gb is not swiching on nor it is showing in my laptop plz give me the address of philips service center in meerut (uttar pradesh)
Nov 08, 2010 | Philips GoGear ViBE Digital Media Player
Newly purchased philips gogear (frozen)
Go to Philips website and update the firmware to resolve most freezing issues (as long as they are not hardware-related).
Feb 23, 2009 | Philips GOGEAR SA6045 MP3 Player
Headset in problem at socket pin side
Try a different set of headphones - if these do not work, call Philips and redeem your warranty if it was purchased within the last year. Headphones can be replaced, but headphone jacls cannot be repaired.
-Tha Mp3 Doctor
Jan 04, 2009 | Philips GOGEAR SA6045 MP3 Player
Lost memory on my philips gogear 2gb
3 different problems:
ashton -
If your GoGear is an HDD model, then it is incompatible with both Vista and Windows Media Player 11. If you have Vista, forget about this player. If you have XP, roll back your Windows Media Player to version 10 and try running a Repair in Philips Device Manager - the damage might already be done, but it is worth a shot.
If you have an SA model GoGear, get the latest Philips Device Manager from Make sure you enter your correct model # in the website, or you will damage your player. Run an Update in the updated Philips Device Manager to upgrade the firmware to fix the freezing issue. Philips has a weird quirk that if you want to really upgrade the firmware, you have to also update the Philips Device Manager first or the Device Manager from the CD will give you a false positive: "Your device is already up to date."
mwungura - You problem may be hardware related, which will require a replacement, but here's how we'll find out: First, make sure the hold/lock switch is not engaged. Try turning your player on again. Consult your manuals for details on what I have just said. Second, try resetting the player - the Philips website/user manual will tell you how to reset your particular GoGear. Third, download the latest version of your Philips Device Manager by going to Philips website. Once you have done that, first run the Update function to upgrade the firmware. Finally, run the Repair function in the updated Philips Device Manager. If all of the above methods fail, call Philips and find out how to get an in-warranty replacement (or take it back to the store).
Guest - your player is screwed - there is no software available for fixing that problem. Call Philips and find out how to get an in-warranty replacement (or take it back to the store). The problem was caused because you deleted a key system file when you were trying to delete music - next time, be very, very careful.
-Tha Mp3 Doctor
Dec 14, 2008 | Philips GoGear SA178 MP3 Player
You have to do the "update" in the Philips Device Manager (make sure you are connected to the internet when you do) to repair the corruption: Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 10, 2008 | Philips GoGear HDD6330 MP3 Player
Frozen screen
reset the gogear pres the power and volume + at same time
Apr 19, 2008 | Philips GoGear HDD6330 MP3 Player
Phillips 2GB mp3
Make sure you got the one with GoGear docking station instead of the one with Ipod Docking Station.
Here's how to fix the player:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 26, 2007 | Philips SA5125/37 MP3 Player
Memory corruption
My mp3 player Philip SA51xx 2gb says "memory corruption please repair it now" can I ask your hepl to fix the problem thank you
Dec 24, 2007 | Philips SA5125/37 MP3 Player
1,022 people viewed this question
