Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Stk for sony 51'' tv
Colours are double in blue and yellow. One of the repair person told me this is stk's problem.Could u tell me how much its gonna cost me with labour?
  • 579 Answers
The parts don't cost too much, but do take about an hour to install. The worst part is in having to redo the entire convergence procedure after the new STK amps are in. Probably loking at $300 to 450 depending on what part of the country your in.
Posted on Jan 01, 2008
The tv shows only red and blue it projects three
You need to replace Both STK ICs . They are Big Black ICs and will have PN# on them
example STK392-110
Mats has ICs 1-800-628-1118
Also check the Pico Fuse in Front and back Of ICs they look like resistors ,But will be Green or Yellow 5amp, 6amp, 7amp.
Feb 22, 2011 | Sony KP-51HW40 51" Rear Projection...
Blue and yellow, like double vision or 3d look
The convergence circuit has failed in the tv. These are the big STK chips on the circuit board. It typically costs $300 to fix at a TV service center. Requires replacement of two STK chips, some resistors, some fuses and then re-alignment of the CRTs within the service menu.
If you have proper soldering tools and can download the service manual, it is possible to do the repair yourself.
If you do not have any electronic background whatsoever, I do not recommend a person to attempt it.
Feb 20, 2011 | Televison & Video
How do we fix words with double vision on the screen
You most likely have Convergence Failure. This page will help you confirm the fault: Convergence Gallery . You have 2 choices:
  • Morph into an electronic technician, find good quality STK ICs and repair the TV yourself.
  • Call a competent and reasonable TV Repair person to do the job for you.
easyab@hotmail.com
Feb 11, 2011 | Sony KP-51WS510 51" Rear Projection...
We have a Sony KP046WT510 rear projection TV and the picture went to what I describe as what a 3D movie looks like without the glasses. I have tried to adjust the convergeance manually and red and blue...
THIS model uses two of the STK-392-560 CHIPS for this.
Both will have to be replaced and I can tell you best place to buy them and how to do the repair.
Total parts cost will be under 25 dollars from the seller I use on EBAY.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
e0c5637.jpg The two chips look like this but will have STK-392-560 NUMBER ON THEM.
Typical convergence problem
Aug 26, 2010 | Sony KP-51WS510 51" Rear Projection...
I'm getting double color images of yellow and blue on the sides of the screen
You need to replace the two STK-392-560 CONVERGENCE IC chips this set uses.
This may be a do it yourself job if you have some skills, if not most shops charge a lot for this kind of repair.
Let me know if you have questions or need advice-I am here to help.
SD TECH
May 26, 2010 | Sony KP-51HW40 51" Rear Projection...
Blue color is causing a miror effect
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 26, 2010 | Sony KP-57WS500 57" Rear Projection...
Gettung double imaging with blue and yellow
Double check the model number---there is a 61swx10b---All of these sets use two STK-392-110 convergence chips.
Check my recent posts and you will find similar ones related to your TV. Both chips need to be replaced and you can buy them on Ebay for less than 20 dollars for a pair including shipping. Depending on how they fail there may also be a damaged resistor located near them.
If you cannot do this repair shop around your area as most shops will try to charge 300-400 for this repair.
Make sure whoever you get replaces both chips or you will shortly have the same problem again.
I have done hundreds of these sets and here charge 200-250 for this kind of repair. If a shop tells you it has "to go to the shop" keep looking as any good tech can do this repair right in your home in about 1 hour.
I hope this information has been helpful and if you have ANY questions or need advice contact me.
SD TECH
Sep 25, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Sony kp-51ws510 51' projection tv
There are resistors that need changing and maybe small fuses.
Nov 28, 2007 | Sony KP-51WS510 51" Rear Projection...
Picture is Distorted, red/green/blue curves
you have bad convergenze this fault is common and need qualified person to change the STK ic's call repair man please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
