If you are using component cables to connect your television and they are improperly connected, this can cause a greenish picture. If this is the case make sure that they are in the correct inputs on the television, these inputs are color coded for your convenience. If they are in the correct inputs make sure that they are pushed in all the way.
From technical experience:
It could also be related to a faulty MPEG2 or AV_TERM Board
good luck,
mrwindex
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank you very much it was the cable wire connected to the cable box...Worked like a charm..
Thanks again,
Luis
" - lm125m
have un=plugged the LCD-HDTV, and also held the power button on for 5 second in order to see if it...
(More)
have un=plugged the LCD-HDTV, and also held the power button on for 5 second in order to see if it will reboot, but it just make a double clicking sound and the set never comes on.
The blinking Timer Rec LED just keeps blinking 3 times , then off, then 3 times on .... over and over again, but TV doesnt come on. Please help.
I have the same thing, only its on both sides of the tv. But after my tv has been on for a little...
(More)
I have the same thing, only its on both sides of the tv. But after my tv has been on for a little bit, it goes away. Makes me think its something to do with heating it up. I dont know what to do. Its only 1.5 years old
I have a 32' Toshiba Flat Screen TV and it has the DVD player already installed...I also have...
(More)
I have a 32' Toshiba Flat Screen TV and it has the DVD player already installed...I also have comcast and I can't find a way to get the subtitles off...So if you could help me I would greatly appreciate it Thnxs
