Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Too much water coming out.
As it should, no water comes until I press the trigger, but when I press the trigger water pours out way too fast -- emptying clean solution reservoir in several seconds and drenching my carpet.
  • Anonymous Sep 29, 2008
    I will try rinsing mine. It seemed to work ok at first, but after an hour or so the water was just going out whether I pressed the trigger or not.
  • Anonymous Mar 29, 2014
    Trigger does not cut off
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Posted on Jan 24, 2008
Hoover spin scrub 50 leaking from bottom
Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was stuck in the open position, which poured the water out continually!
Apr 09, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
What setting do I need to have the machine on to **** up the excess water? I want to download the manual but can't seem to find a link to do so, how would I do that?
You should have the vacuum set to Wash/Rinse for all steps in cleaning. Press the trigger to release the cleaning solution and push the vacuum forward. With the trigger still pressed, bring the vacuum back towards you). Then release the trigger and again move the vacuum forward and then back. Repeat the "dry" strokes until the dirty water enters the dirty water tank. Watch the water going through the dirty water tank lid. Empty the dirty water tank if the suction fails or the tone changes. Do more dry strokes after cleaning the entire surface until you do not see more water entering the dirty water tank.
The manual is available from Hoover at the product site: http://hoover.com/products/details/f7411900/max-extract-dual-v-widepath-carpet-cleaner/ . The direct link is here: http://hoover.com/file/592/ .
I hope this helps.
Aug 08, 2011 | Hoover SteamVac F7411-900 Upright Vacuum
Vax Carpet shampooer V - 027CC. water not coming through when trigger pressed. Bottle is filled.
Check that the outlet bung at the bottom of the bottle is not jammed closed or that the operating rod from the trigger has not become dislodged. It is best to remove the bottle from the machine to do this.
Jan 16, 2011 | Vacuums
When i press the trigger for water to come out it doesn't?
there is a very weak plastic plunger under the trigger on the hose, if that is the one you are speaking of. mine broke shortly after i bought it. i just bought a replacement hose and used epoxy to build up the trigger for holding it's position better without snapping off.
Jun 05, 2010 | Bissell 9200 Upright Vacuum
No water comes out when you press the trigger only solution comes out when you turn it on its side
Check the belts. Most models have two belts. The first one from the motor runs both the brushes and the water pump.
Oct 02, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do I fill it and start it?
yes you should have got a cup with it to fill it then wait till it heats to steam
May 26, 2008 | Scunci 900 Handheld Steam Vacuum
Water coming out w/out trigger being pressed
You may have a problem with the valve at the bottom of the tank, or a water line has come loose. How old is this, there is a 1 year warranty, so if less then a year, take it in for repair.
Feb 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Plugged water line?
The trigger in the handle is clipped into two plastic snaps. When the trigger is pressed, the trigger pivots in these snaps and the pressure is transmitted through a rod connected to the trigger down to a valve located under the water tank. If the machine has been carried by the top handle insead of the carry handle that is incorporated into the water tank, the extra stress on the trigger will break off the snaps and the trigger will not function properly. Take the water tank off the machine and press the trigger. Observe the valve below the tank support and see if the rod is pressing down on it.
You might also check the hoses that come down the handle where they turn at the bottom of the tank. Sometimes they kink there and this will restrict water flow.
If you have been using the wrong shampoo, that is shampoo not designed for hot water extractors, it is possible for it to congeal in the lines and plug them.
Jan 27, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
445 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
