Question about Aiptek DV5100M Camcorder
Won't turn on.
I put in new batteries, the led is on, i don't have the manual for it and i can't figure out why it won't turn on.
  • Ken Kadar
    Ken Kadar Jun 03, 2008
    put it thru the scanner at a airport and now the screen lightsm up butm dont see anything,ie menue ect.
    ken
    Problem Solver:
  • 8 Answers
Klore;
There is a switch under the LCD; make sure it is set to "on" position. Here's a link for the manual; http://www.goaiptek.com/manuals/manual-pkdv51.pdf
zoly;
Sounds like your unit is toast. The flash on the main board has been deleted. I simply do not think that can be fixed, but HANG ON TO IT! I have been wrong many, many times. Research ways to reflash the unit; not very easy with today's save-a-buck manufacturing methods, but dang worth a try. I'm very sorry for your loss. :(
Posted on Jul 27, 2008
Lookin for manual on 2003 pontiac grand am 2.2 16valva what manual matches this engine
have you checked for spark you don`t say. also if you order a manual for your specific car and engine size you won`t have a problem.
Sep 20, 2014 | 2003 Pontiac Grand Am
My U200E won`t charge unless it`s completely dead and the touchscreen won`t work anymore
Hi Bell, please don;t panic. Let us try to solve it.
> remove -- and don't replace -- the battery, than connect the charger and turning on the Laptop.
> also check the charging LED is turned On.
> if its working than check the battery else check the charger.
Feel free to revert back if issue not resolve.
Thanks
Nov 07, 2013 | ASUS Computers & Internet
Razor ground force battery says its fully charged but gokart wont turn on
Here is the owners manual for the future (in case you don't have one.)
http://www.meijer.com/assets/product_files/pdf/1000422_groundforce_manual.pdf
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
Aug 19, 2012 | Razor 300001-SL Ground Force Go Kart
Doors don't unlock when car is put in park
I believe this is a user settable option(went back to factory default when the battery died).The owners manual would be the place to look!(If you don't have the manual,scour the wrecking yard for a same year/model in a glovebox).You probably have to do some annoying sequence to change this option,most likely you won't figure it out by trial and error(it's usually changed by holding the lock or unlock button while putting in park while standing on your head and *******(hee-hee!) or something stupid like that.
May 26, 2012 | 2002 Toyota Camry
Aod255e wont boot
what is the meaning of won't boot. is your laptop powering on or not. did you see any leds lighting up.
if leds are lighting up then it might be a incorrect ram seating or hard disk might be not connected properly.
if no leds are lighting up. then check your system with the adapter connected.
if it is turning on by adapter connected. then your battery is dead. try to replace your battery.
if you have done all of this. just reset the bios.
WARNING: if you don't have any knowledge of opening a laptop, then don't do the following steps. it is your responsibility for any unnecessary damage.
just open the back cover and reset the bios settings by removing the CMOS Battery inside the laptop.
if you have done this also. take your laptop to ACER service center
Feb 17, 2012 | Acer Aspire One Aod255e-13648 10.1"...
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
99 windstar van, won't turn over,won't start, headlights won't turn off,
baterr ywas dead changed it-new battery worked-discharged once air turned on-put in 2nd bateer yseems fimne as long as you don't turn on the air-if you do there is a clicking inside radioconsole and discharges battery
Jun 17, 2011 | 1999 Ford Windstar
I have a 2007 street bob took it out of basement charged battery and started right up.now bike wont even turn over battery had over 12 volts starter checked out alright replaced batteries in fob cant...
I can't figure out whether your problem is with the bike or the security system. I have no experience with security systems and don't have a clue. I'd take the battery out of the bike and take it somewhere to have it "load tested". Just because a battery shows 12 volts with a meter doesn't mean it's any good. Put a load on it (like the starter does) and you may find that it's a piece of junk. If it won't start then, I'd suspect the security system has it locked out. Sorry I can't help with that but I'm an old school biker and I don't mess with security systems.
Good Luck
Steve
Apr 13, 2011 | Harley Davidson FXDBI Street Bob...
Aiptek DV5100M Camcorder Logo
42 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Michael Galve
Michael Galve
Jose Ma DM.
Jose Ma DM.
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
