I am not sure what an over reign SLM 1500 is and I have never seen a power mower with a plastic blade but in order to remove the lower belt guard from most walk-behind, self propelled lawnmowers so equipped, it is necessary to remove the blade adapter from the bottom of the engine shaft to allow the guard to slide off.
To remove the blade adapter, tip the mower to where you can spray some penetrating oil on the shaft above it and let it soak for a little while. When you think it has had sufficient time to soak down between the shaft and adapter, set it up on your work bench if you have one available or you can do this on the ground as well. Tip the mower back on the handle bar (this will keep your oil from running out into your air filter and clogging it), secure it in the fully tipped back position, take a small hammer and tap downward on the blade adapter while pulling downward, away from the engine at the same time. Use caution not to strike it so hard as to damage or break it. They usually slide of with just a little bit of effort. Once the adapter is off you can easily remove the plastic guard. When reassembling it, I always use a little anti-seize on the adapter to make it easier to remove next time.
