LG 42lb5d has audio but no picture, but this only happens sometimes when I turn it on. Sometimes it is fine. When it does happen i just turn tv off then on again until it fixes it. I had this tv serviced when it was under warranty. They replaced the panel and all the modules, and it still occurs. tv is out of warranty now.
They may have missed out the power supply circuit. There may be loose solders or bad parts. You may have eliminated other parts which may have caused the problem when the service center replaced the parts. Inspect those that you still have remaining for leaking capacitors, loose parts or loose solders.
TV screen blank, when pushing power button it turns green and contactor switches. If you push menu...
(More)
TV screen blank, when pushing power button it turns green and contactor switches. If you push menu button nothing appears on screen.
Need support base/stand for 32LG3000ZA. Originally wallmounted and therefore put base away but...
(More)
Need support base/stand for 32LG3000ZA. Originally wallmounted and therefore put base away but unfortunately has inadvertenly been thrown away. Any suggestions
LG 42lb5d tv has lost the ability to use the remote or side buttons. When you plug tv in, it turns...
(More)
LG 42lb5d tv has lost the ability to use the remote or side buttons. When you plug tv in, it turns on. Pressing any of the side buttons (like on/off) does nothing. Remote when used does nothing,but green light on from of tv does blink.
