Question about Tech Solution TS-8000 Cross-Cut Shredder
Shredder suddenly runs only in reverse
I shredded a significant amount of paper recently, and now my previously reliable TS-8000 will not shred anymore. It does operate in reverse, but not "forward" Help....shredded too much paper and now my Tech Solution TS 8000 only works in reverse. I a have made sure no peper is stuck in it... and I carefully wiped the sensor with a dust cloth? ANy suggestions?
    President:
  • 1,944 Answers
  • Damen Wong
    Damen Wong Jan 01, 2008
    Exact same problem as yours.
Repair. reverse is OK but will not shred
There is a light sensor that is blocked by the paper that tells the machine to turn on when paper is loaded for shredding, it is most likely blocked with debris for a previous shredding.
Aug 11, 2016 | Omnitech 12 Sheet Cross Cut Shredder
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
May 31, 2010 | Tech Solution TS-4500 Shredder
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Techsolutions TS-8000 runs continually when switch is on. Normally you need to feed it to start is in the on position
I have a TS2500 and it behaves in a similar fashion. It sounds like you may have a paper jam keeping the paper sensor switch turned on. The first thing to do is make sure that the container that collects the shredded paper isn't full. Everytime I fill mine up I have this problem. Emptying the bin and pulling the shredded paper from the bottom of the unit usually allows it to automatically shut off. If that isn't enough, make sure that you don't have a paper jam in the cutter rollers. The most important thing you can do is make sure the unit is unplugged before doing anything with the shredding mechanism.
Hope this helps.
Dec 09, 2008 | Tech Solution TS-4500 Shredder
Sounds like the sensor/switch that detects when the basket is full of clippings is stuck in the "full" position. UNPLUG this potential finger-eater and poke around on the underside with a pencil or something.
Feb 27, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Tech Solution TS-8000 Cross-Cut Shredder Logo
926 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Marvin
Marvin
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
