Question about Acer Aspire 5610-4648 Notebook
Blank screen hit start button I here fan running then shuts off ? also boot light flickers for a second and thats it?
    Sergeant:
  • 263 Answers
Hard drive problems try to restart the computer and press the F8 key in the first 5 seconds this will display the page with some options choose last good know config or save mode if last know good config does not fix it try save mode if you can acces the hard drive you may have re install windows if no acces get new hard drive
Posted on Jan 01, 2008
Desktop runs but won't boot
Normally if the hard drive is bad you will get some type of message on the screen.
If it sounds like it is running but the screen is blank, then try another monitor. Maybe the monitor is bad. Try another monitor. Borrow a monitor from a neighbor, friend, relative or co-worker and put it on the computer. If the borrowed monitor works, then your old monitor is bad. If the borrowed monitor does the same thing, then your video card is bad.
If it does not seem like it booted up all the way then try the steps below.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 09, 2012 | HP Computers & Internet
HP Compaq 6735s Laptop screen was blank when turned on
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
Toshiba Satellite P25-S5093 screen/boot problem
the memory cards are loose or are dirty and need the contacts cleaned with pencil eraser.
when the memory cards lose connection you lose video on screen.
Jun 18, 2010 | Toshiba Satellite P25-S5093 Notebook
Dell computer won't start up.
if you have 2 memory sticks, (i.e. 2 ram sticks that are 2 gb each) try putting on in and start it.  if it does not work try this.
remove all power supplies (cord and battery).   hold down the power button for 30-60 sec.   after that plug the power in and try turning it on.
Mar 09, 2009 | Dell Inspiron 5160 Notebook
Medion Desktop won't boot. Flickering power light????
I agree with the hard drive solution. I would check that first.
Dec 25, 2008 | Medion MD-1704 PC Desktop
LCD monitor turns off after 2 seconds from boot
Try to see the video card and fell if it is hot, if the fan is running when turn on. There is a part of your computer that is hot, that when reach to that temperature it trun blank or off.
Thanks
Nov 19, 2008 | Dell E173FPc 17" TFT LCD Flat Panel...
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
Acer Aspire 5610-4648 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
