Question about Frigidaire GLTF2940ES Front Load Washer
Need to know how to replace belt on kenmore front loading washer
The tub will not spin water goes in but the tub will not spin so I believe the belt needs to be replaced but I am not sure how to go about it. Its a Kenmore stackable with the dryer on top. Any help would be greatly appreciated
  • 1 more comment
  • robbykathie Jan 01, 2008
    well it was making noises and we smelled rubber but we are not sure how to find the belt do we take off the front or look in the back
    we smelt rubber burning but now it will not spin the motor sounds like it wants to work but does not spin
    but we do not know how to even check the belt do we check it from the front or the back?
    Sergeant:
    Champion:
  • 310 Answers
If its a belt you should of smelt the belt burning.and the motor will keep spining wich you should here. try unpluging the unit and looking for a reset switch. most of the time its the clutches like on a car.
Posted on Jan 01, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Please first check if belt is broken? If not How old is the unit?
  • Rene Jan 02, 2008
    Alot of front loaders have no bottom panel...so easy way is to bring it out lean it back and look underneath. if this is not possible yes back panel. if you do this please check which screws are holding the panel...some are for internal components....and of course be safe and pull the plug or circuit breaker
  • Rene Jan 02, 2008
    ps have you moved the tub around by hand to check it's rotating...sometimes they can become jammed for various reasons. sorry should have asked you before....not used to doing it this way...it's easier when it's front of you. if the belt is still connected you should hear the motor spinning if not the bowl will spin to freely
How do I check the belts or springs holding the washer tub
to check the belt or Air shock , its easy to remove the rear access panel , you can have a look for shock and motor & belt but there are a lot of reason for your complaint for doesn't spin out water and noisy when spinning it may be have kinked in the drain hose or the spin start before pumping water out properly leads to load unevenly distributed in the movement of the drum, so i believe that your problem in pumping the water out. Alaa Refaei
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Once it goes to the last spin cycle ,( the fastest one) it starts making a thumping sound . could it be a belt or bearing?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 13, 2011 | Kenmore HE2 Plus Front Load Washer
My Kenmore front load 4304 washing machine tub
I would need the complete model # to get you a breakdown showing the piece i believe to be broken and in need of replacement. I believe this Kenmore F.L. was built by Frigidaire and they have had a problem with a specific piece on this machine. I will be glad to help once you get me the full model, should be around the opening of the door.
Oct 25, 2009 | Kenmore 43042 Front Load Washer
Tub will not spin up
It's usually the teeth are broken/worn off the plastic gears. Sounds like one side may be ate up. Check your belts and gears.
Jun 28, 2009 | Kenmore 44072 Front Load Washer
Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Mar 02, 2009 | Kenmore 43142 Front Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
123 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
