Question about GE WDSR2080D Top Load Washer
Will agitate, but will not spin
My WDSR2080D will fill, drain and agitate but will not spin. After the water is pumped out, there is no click. the washer just humms
  • 6 more comments
  • Anonymous Mar 06, 2008
    My Ge washer will drain but not spin and it is not over loaded
  • unique6386 Oct 27, 2008
    mine goes thru the wash cycle, drains then keeps making the draining sound will not go on to the rinse cycle, if you leave it in wash cycle, it turns itself off
  • 76Lory Dec 15, 2008
    My washer agitate, drain, but not spin and also in ocassions wash without water.
  • bandwhughley Dec 29, 2008
    does everything but will not spin
  • johnmaroun Feb 14, 2009
    my ge profile WPRB8050 will not spin but it agitates, is that a controle or a mechanical problem???
  • Scott Glauser
    Scott Glauser Apr 08, 2009
    GE WDSR2080 fills, agitate, but will not spin. I sounds like the pump is working and all the water is pumped out. I've found that to be the spin solenoid in the past, but I don't even know how to opent this thing....
  • Anonymous Mar 19, 2014
    machine will fill hear a clicking when it should be agitating and won't drain
  • Anonymous Mar 20, 2014
    has power and have tried all settings but wont fill and wont spin and is full of water
Hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Posted on Feb 17, 2008
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Washer filles with water can hear timmer then drains never spins
you have transmission problems. When your washer is empty and off you should be able to turnthe agitator by hand if you can't then the transmission is bad.
Apr 03, 2009 | GE WDSR2080D Top Load Washer
GE washer won't spin
you need to post your model number
Mar 31, 2009 | GE WDSR2080D Top Load Washer
GE WJSR2050T2WW Washer fills up,Spins but won't drain out?
The most common reason for no pump out is a blockage in the pump. Best to drain as much water as possible. (even laying the drain hose down to allow as much of the water to drain out as possible) Un-plug washer. Next, open the front of the washer by using a putty knife to push in and release the clips about two inches in from each side at the seam where the front panel meets the washer top. Pull the front panel forward and lift it off the bottom pegs. Remove spring clamps from inlet and outlet of pump with a plier. Remove two pump mounting screws to allow pump removal after unplugging electrical leads. Remove obstruction from pump. Most pump bodies can be separated if necessary. Reassemble, plug back in and test.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Pos ge washer WCSR2080B
Sounds like u might be having trouble with the lid switch.. U need to also check you water pump out.. this model has a electric pump that may be plugged... dont take much to plug this pump up.. have you taken front panel off yet ? Post what ya find
Oct 16, 2007 | GE WDSR2080D Top Load Washer
GE WDSR2080D Top Load Washer Logo
648 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
