Candy CDC266 Dryer
Problem for Candy CDC266 Dryer
Dryer wont heat up
By karen_mulhol on Oct 27, 2009
dryer wont heat up
Solution #1
posted on Oct 27, 2009
Not Rated)
rogrrabbit
Rank: Guru  Washers & Dryers  Expert
Rating: 90%, 226 votes
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad
Was this helpful?
Yes
No
Popular Solutions for Candy CDC266 Dryer
Questions and Unsolved Problems for Candy CDC266 Dryer
Do you recommend Candy CDC266 Dryer?
Answer
Answer
my water full light comes on after a short period and stops machine leave for 30 mins or so and it... (More)
Answer
when i turn on my candy condenser dryer it starts but will not stay on unless you keep finger on the... (More)
Answer
my drier is making a terrible noise the felt seal inside has come out and so has the rubber seali... (More)
Answer
water leaks on the floor during operation. water collector fitted correctly.
Answer
The door does not stay closed.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Candy CDC266 Dryer:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
