If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Was this helpful?
Yes
No
Popular Solutions for Kenmore 3.8 cu. ft. HE3 King
Washer has a loud thumping noise on high speed spin, checked behind rubber gasket and the plastic...
(More)
Washer has a loud thumping noise on high speed spin, checked behind rubber gasket and the plastic fins are all broken. why and can I fix?
the rubber seal in the front became loose and the wire part came out - can i fix it? Replace the...
(More)
the rubber seal in the front became loose and the wire part came out - can i fix it? Replace the seal? fix to it? model 42844403
