Yamaha RX-V470 Receiver Shuts Off
This receiver powers up and then shuts off within 2 seconds. The outputs are all good and there is no DC present in the output stage. The bias on the base of the power relay driver is being removed by the micro and I dont know why. The protection circuit does not appear to be activated in any way. The speaker protect relay does not have a chance to engage because the amp does not stay powered long enough.
Any assistance with this would be greatly appreciated.
Thank you,
Joe Weibel
  • 3 more comments
  • boxster Mar 02, 2008
    I have the same problem. Sometimes the power will stay on up to 45 seconds, but most times it powers off almost immediately.
  • Greg Famularo Mar 23, 2008
    I have a RX-496 with the exact same problem. Anyone with ideas to resolve, please pass on.
  • jegp2 Aug 03, 2008
    I have the Yamaha RX V470 it will power up and then shut off .....I know there is nothing really deeply wrong because if i sit there for 45 minutes turning it on and then off in a random order of trying to turn it off before it actually turns itself off and then try it again and again eventually it will stay on and work properly forever until I turn it off again and then the process starts over next time i use it
  • TREVORDV Nov 24, 2008
    Same problem with the yamaha RX -657.Shuts off after two-three seconds.
    Have it for four years now and never had a problem until yesterday.
    HELP PLEASE !!!
  • kewyman Jan 13, 2009
    Same issue.. just started this week with my rx-v470. Happens with and without anything hooked up to it. Turn it on and it powers off within 2-3 seconds.
  • 4,234 Answers
This unit is in the protection mode. See the link below. If you have further questions, please post them here.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Aug 19, 2010
Receiver shutdown
change your power regulator it is leaky and there are some diodes around the regulator change them also check the caps and some of the resistors some also can be faulty.good luck.
Jun 07, 2007 | Yamaha RX-V1500 Receiver
I have a yamaha, natural Sound Av receiver RX-V483, every time that i start the unit it will shut down after 5 seconds. thank you very much
It indicates an output load problem, dis-connect the speaker wires from the back of receiver. Next power on and turn the volume right down, if the unit runs, check for shorts in the speaker wires and speakers. But if it still shuts down "with speakers and wires dis-connected" one or more of the audio output ic's is shorted and will need a professional to assess the item.
Feb 02, 2011 | Yamaha RX-V463 Receiver
Re: Yamaha RX V670 Receiver Powering Off
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics ledstiles@hotmail.com
Apr 23, 2010 | Audio Players & Recorders
Yamaha RX-V595a receiver shuts off 2 seconds after its powered on
The first thing called out is the impedance switch on the back is not fully in one or the other position. Cycle the switch back and forth to make sure it will 'read' each setting, then turn it on.
Also make sure you if you have anything connected to its convenience outlets that they are not drawing more current than is allowed.
Did you buy it used or new?
Mar 09, 2010 | Yamaha RX-V595A Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
My Yamaha RX-V470 Kicks off after a couple of SEC.
Two possible problems , bad memory back up cap or weak voltage regulator.
Jul 10, 2009 | Yamaha RX-V995 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
The receiver sound shuts off
There is a problem with the receiver that is allowing DC voltage to get to the output amp section. This is detected and the protection circuit shuts down the receiver. Yamaha uses coupling capacitors between sections to prevent this. If one of these is defective, it would explain your symptom. This should be a relatively simple repair for a repair shop. Expect $10-$25 for parts plus the local labor rate.
Dan
Mar 18, 2008 | Yamaha RX-V992
Receiver shuts off at times
There is some leakage of DC voltage getting to the output section. DC voltage will cause the protection circuit to kick in and shut down the amp. This should be a relatively simple repair and cost about $15-$30 in parts plus the local labor rate.
Dan
Dec 14, 2007 | Yamaha RX-V992
1,139 people viewed this question
 Grubhead
Grubhead
