Question about Kenmore Elite 45986 Front Load Washer
Replacing the rubber gasket on Kenmore elite HE 3t
Can you explain how I can remove large rubber front door gasket for cleaing, mine is mildewed? Thanks. Jerry
  • Annjam Jan 08, 2008
    The rubber gasket has moved creating a gap that allows water to run to base of drum and then spill out through the bottom on to the floor. I have tried straightening the gasket but I can not get it to move. Any ideas?
  • SusanAmy Jan 09, 2008
    My Kenmore Elite HE-3 frontload washer has mildew in the rubber ring. I have read that this can be caused by too much detergent, but I use a fraction of the recommended amount. I have not been able to remove the mildew with bleach or KABOOM. Does anyone know of a product for this?
    Master:
  • 619 Answers
Probably some rubberize installation are screw to the case or body/ you only need pollout are screw driver philips or flat .
Posted on Jan 10, 2008
6ya staff
SOURCE:
Kenmore elite he3 gas dryer, how to fix blower assembly?
take it it's a front load, well remove the top panel, this will allow you to get to the screws to remove front panel. remove bellows pad (rubber gasket around door) remove with a screw driver carefully there will be a metalic ring, remove it fold bellows pad back.Now you can remove front panel and access the blower motor
Sep 19, 2013 | Kenmore Elite HE4 Electric Dryer
How do I clean the rubber gasket on my front loading Kenmore clothes washer?
have the same problem with a samsung frontloader - it gets all mildewy. The tech support said to leave the door ajar between washes so it dries. will it remove the existing mildew? dunno.
Oct 15, 2009 | Kenmore Washing Machines
Replacing the rubber seal on the door
The following link explains how to replace the door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions, please let me know. I hope this helps you.
NOTE: Review some of the testimonials as well. One user (DGBG) offers a quicker way of replacing the bellow if you're willing to give it a try.
Oct 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 'elite' HE3 front loading washer
I have the same problem. Nothing works fcfor the mildew. i have bleached it, used simple green and used baking soda. That washer is the biggest piece ever!! Good Luck!
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Water leaks from bottom of machine
is the gasket on the filter in one piece or has a line come off the pump? mine it was the output of the pump.
Feb 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Replacing Door Gasket on Kenmore Elite HE3
The following link explains how to replace the door bellow on a Kenmore front loader:
Replacement door bellows can be purchased online at searspartdirect.com. Just type in your model number and look under the "Door and Latch" heading for item number 5 (part #8181850). I would also suggest items 6 and 14, which are the front and back bellow clamps (if needed). Sometimes the clamps can break.
To keep your door bellow clean and free of mildew in the future, I recommend you read the following link:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own, one these models and have never had a mildew or odor problem by following these simple steps (and I have a family of 8). If you do not like leaving the door open, because of small children, the control panel can be locked so the controls cannot be manipulated. Do this by pushing and holding the "Drain/Spin" button for 3 seconds (this information shouod be printed on the control panel under the button).
I hope this information helps you.
Nov 13, 2008 | Washing Machines
Mildew
all front loads all brands have same issue with mold people today tend to use less bleach CHLORINE BLEACH that is ..allow machine to fill with hot water normal wash pour 2 cups CHLORINE BLEACH in water allow to wash a few min to mix open door and with cloth wash inside of door gasket be sure to roll gasket back and wash underneath lip allow to finish complete cycle should remove most of mold try to this every few months..also leave door open between use to allow moisture to dry out as much as possible like i said YOU ARE NOT ALONE
Jun 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
591 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
