Question about Whirlpool LGR8648 Gas Dryer
Burner wont light
I have a whirlpool gas dryer. model # lgq9858lg0. the dryer will run but burner wont light. we replaced flat ignighter & thermalcouple. did not fix the problem.
  • mypop1 Jun 18, 2008
    whirlpool LGO 9858PW! Unit is about 2 years old . Runs fgeels like heat is there but doesn't dry . You have to run aty least 3 times. Before I cal a repair guy I want to see if there is any apparent answer
  • Anonymous Mar 25, 2014
    after 10 min. burner shuts off and wount come back on till it cools down
  • 770 Answers
There is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
Posted on Jan 26, 2008
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
Gas dryer not heating properly, burner ignites at start up, then runs a little while, then wont start again
The gas valve coils are getting weak. Replace the gas valve coils.
Go to repairclinic. com and out in your model number for a good price.
Jan 06, 2010 | Whirlpool Dryers
Dryer won't heat up. Replaced ignighter, still
I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized these solenoids open the gas valves to permit gas flow to the burner. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 11, 2009 | Kenmore Elite HE4 Electric Dryer
I have a whirlpool dryer "LGB6300LW0", that isn't drying. The burner comes on and will go out and come back on. This I guess is to keep the tempature consentant.But after a while the burner doesn't come on...
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Lift Cover on lint filter. Remove two screws Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components, if present, will be on left
Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Sep 04, 2009 | Dryers
Burner will not light ignighter lites timer on automatic will not move timed side will whirlpool
I'm almost 100% possitive what you need to do is replace the gas unit coils - which is a very easy process.
Aug 18, 2009 | Whirlpool Dryers
Burner wont light
If you have replaced the igniter and the thermacouple. Your next item is the gas valve. This is not that hard to change out, but is probably the most expensive part on the dryer.
Please rate this solution
Aug 02, 2008 | Whirlpool LGR7646E Dryer
Whirlpool LGR8648 Gas Dryer Logo
212 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
