Candy CDC266 Dryer
Problem for Candy CDC266 Dryer
Workes fine no heat
By karen_mulhol on Oct 27, 2009
workes fine no heat
Clarification Request
Posted by emissionwiz on Oct 27, 2009
if it works fine then it should have heat?
Solution #1
posted on Oct 27, 2009
Not Rated)
sleprocks
Rank: Wiz
Rating: 84%, 47 votes
the temperature thermostats and or heater are bad, on electricdryers, you can ohm out to see what is defective.
There's no heat 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
electric dryer
1 Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2 Thermal fuse
Comments:
Oct 27, 2009
- the temperature thermostats and or heater are bad, on electricdryers, you can ohm out to see what is defective.
2. Thermal fuse
3. Igniter
electric dryer
1 Heating element
2 Thermal fuse
Was this helpful?
Yes
No
Popular Solutions for Candy CDC266 Dryer
Questions and Unsolved Problems for Candy CDC266 Dryer
Do you recommend Candy CDC266 Dryer?
Answer
Answer
my water full light comes on after a short period and stops machine leave for 30 mins or so and it... (More)
Answer
when i turn on my candy condenser dryer it starts but will not stay on unless you keep finger on the... (More)
Answer
my drier is making a terrible noise the felt seal inside has come out and so has the rubber seali... (More)
Answer
water leaks on the floor during operation. water collector fitted correctly.
Answer
The door does not stay closed.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Candy CDC266 Dryer:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14880
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
