Question about Samsung Cameras
Samsung d75 digital camera
Does the above camera have the "trimming" function
3 Suggested Answers
SOURCE: Samsung D75 digital camera. Having
Problem resolved. My own stupid operating fault. It appears that, in movie mode, you don't just press the shutter button to start a shot, you have to hold it down for a moment. Not made clear in user manual, but I should have twigged earlier.
Thanks for your contact/help.
Posted on Aug 30, 2008
  • 11967 Answers
SOURCE: My Samsung D75 camera's screen's blank & lens permanantly ''out''
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 18, 2009
What battery do i use for the ssmsung d75
High end AA batteries or rechargeable AA
Mar 02, 2015 | Samsung Cameras
I purchased a samsung ES70 compact digital camera last year and lately a black line has appeared across the bottom of the screen, could I get rid of it or would i have to purchase a new camera?
If the line is only on the display and not also on the photos when you download them to the pc, then you only need to have the LCD display replaced. The screen should cost like ~$20 as you can see here:
Mar 30, 2011 | Samsung Digimax S630 Digital Camera
Operation manual D75
Most of the manuals for Samsung cameras are available online. You could locate them either by going directly to the manufacturer's website and then on to the Support section or by performing a search on Google. The Google search I performed was for "Samsung D75 operation manual" and the first result already provided me the manual: SAMSUNG D75 Operations Manual. Simply click on "Get Manual".
Mar 30, 2011 | Samsung Cameras
When i want to take a icture on my d75 camera, it
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting its contents. The position nearest the contacts unlocks the card. If the slide is already in the proper position, try sliding it fully the other way and then back.
If that doesn't do it, try another card.
Feb 13, 2010 | Cameras
Samsung D75 digital camera. Having taken a clip in movie mode, I have a 'standby' message on the LCD screen. Can't seem to get rid of it to take another clip. When I press shutter button I just get a bleep...
Aug 29, 2008 | Samsung Cameras
Samsung d75. when attempting to take photo with the flash, the flash indicator on the back display simply flashes constantly and the flash doesn't go off or a picture taken.
Problem with CP ... U need to take it to a service centre ... Is a common problem and a good technician will fix it for you in no time flat ...
Jul 20, 2008 | Cameras
Samsung d75 won't turn on.
Try pulling out on the lens when you start it up.The lens
might be getting stuck.
Sep 04, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
43 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
