Pentair Minimax NT Heater
Problem for Pentair Minimax NT Heater
I have a pentair minmax nt, natural gas heater. I
By kpsprague on Oct 27, 2009
I have a pentair minmax nt, natural gas heater. I am getting the E04 message. I know its a fan failure but I hear the fan fine. When I start it, and look at all the LED's in the back, all are lit up except the one labeled 'PV' under the light it says 'LED 13'. It does its three tries then the Fan LED turns off and the TFUSE and HiTemp LED stay on. Then brings up the E04. I know the TFUSE is fine because I just replaced it. What might be the problem?
Solution #1
posted on Oct 27, 2009
Not Rated)
Leisure Pool
Rank: Guru  Garden Tools  Expert
Rating: 92%, 65 votes
This problem is most likely caused by a damaged vac tube or bad vac switch. Check those first. The hose/tube may have been damaged, especially if you have any mice running around. It's most likely the vacuum tube, the switch is not as likely to fail but it's wise to make sure both are serviceable.
Was this helpful?
Yes
No
Popular Solutions for Pentair Minimax NT Heater
Questions and Unsolved Problems for Pentair Minimax NT Heater
Do you recommend Pentair Minimax NT Heater?
Answer
Answer
I have a 250K mimimx nt heater that has been inactive since last spring. I just tried turning it on... (More)
Answer
Heater does not heat, and fan does not come on. Only light that glows green on heater is the POWER... (More)
Answer
Mini Max NT, Blower seems to work fine but unit will not light and service light is on, any ideas?... (More)
Answer
the pilot lights fine but the unit will not alway fire up. after some playing with the unit it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Pool and Spa... Experts
Top Garden & Power Tool Repairmen
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
