Question about Maytag Legacy Series Top Load Washer
MAYTAG WASHER SAV205DAWW
NEED HELP IN PUTTING A NEW BELT IN. CAN'T GET TO THE OLD ONE TO TAKE OUT i just need to know how the belt goes back on the old one got broken,and i did not see how it was on.
  • ASWNewb Feb 23, 2008
    I don't know if darabbit took you up on your offer, but I would. I've got this same model, and could use some tips on how to fix it.
  • tinker maddox
    tinker maddox Aug 24, 2014
    what is the capacity
    Scholar:
  • 196 Answers
This calls for some dis-assembly of the washer. Are you still looking for assistance ?
Posted on Jan 15, 2008
Is it always necessary to purchase a new pump when replacing the belt on top load Maytag Washer? Model No. SAV205DAWW
Not necessary, unless you are suspicious for a problem pump. Or if want to avoid another problem.
Otherwise you must not do it.God bless you
Oct 16, 2012 | Maytag Washing Machines
Maytag washer drum belt worn out....does that damage other parts?
First thing I would do is replace the belt as the old one may have streched
Apr 01, 2017 | Maytag PAV2300 Top Load Washer
Maytag Model...SAV205DAWW leaking water at bottom
there could be 2 things that i know of
first one is that someone bended the door to much and the joint's are eather lose or out of place
the second thing is that the door sealing rubber is out of place, you need to putt it back to place
Dec 27, 2009 | Maytag SAV515DE Top Load Washer
Spin does not work new belt installed when spin starts tumbler not turning belt smoking thank you Douglas. model# sav205daww maytag.
Can you turn the drum by hand ?, if not then the bearings are siezing up
If you can , when the belt was fitted was it tensioned so that there was about half an inch of play on the longest side of the belt
Jun 17, 2009 | Maytag Washing Machines
How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
Jan 08, 2009 | Maytag MAV6200 Top Load Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
How to change belt on maytag model sav205daww.
hi. thanks for the question. pull washer away from the wall. tip back and lean it to the wall .belts are underneath. nice and easy. thanks the appliance doc . please rate me
Oct 01, 2008 | Maytag Washing Machines
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Jan 06, 2008 | Maytag Legacy Series Top Load Washer
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
Washing Machines Logo
230 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
