Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
The orange light on my usb wont turn on. it was working just fine 2 days ago. after my last use i put it on top of my dresser and never touched it. Can someone please identify the problem when the orange light on my USB wont turn on and my computer wont read it. ( I know that the problem is not my computer because my friend lend me his USB which is the same kind of USB as mine and it works perfectly fine on my computer.)
    Problem Solver:
  • 11 Answers
Very good in checking if your computers' USB ports are working. Now that you know that your computer's USB ports are working, try your USB device on his computer and check if it'll work there. If it also doesn't work there, then it'll be your USB device that's not being read.
Posted on Jan 02, 2008
6ya staff
SOURCE:
It won't show up
Use the exact same USB port that you used to install it.
The installation uses a "virtual USB" port.
You also have to use the same user account on the computer. (Use the same USERNAME as when it was installed).
Also, check to see if the computer DOES see it:
Right-click [My Computer]
[Manage]
{Disk Management]
Find your Cruzer in the list or on the graph.
Right-click on it and [Explore]
Copy your homework to your computer desktop.
It should work ok, now.
Oct 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Guitar wont work,
its supposed to be solid check the batteries
Aug 22, 2009 | MTV Games Rock Band for PlayStation 2
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 22, 2009 | Creative Labs Zen Digital Media Player
360 CONTROLLER WONT TURN ON
Try taking out the batteries and then cleaning the inside. Then put in new betteries and make sure everything is plugged in and secure correctly.
Apr 05, 2009 | Microsoft Xbox 360 Controller
Dell Dimension power problem
There are several different solutions for this as posted at this Forum.
http://www.tomshardware.com/forum/51352-2-dell-dimension-8400-wont-boot
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Power cable light is orange and xbox 360 wont turn on
try checking the usb is it damaged? the pins in the usb may be shorted to ground..pry any pins up and the system will work..this happened to me.
Jan 02, 2009 | Microsoft Xbox 360 Console
Canon pixma ip3000 won't print
Check usb cable if they are installed firmly and correctly. Check proper voltage input though designed as Autovolt system.
Try plugging the usb cable on another free usb port or you may try another computer to check if your printer works.
See if there are blinking lights and error codes. You can google for its error codes.
Check flex cable continuity, maybe some rodents have eaten it.
Remove ink cartridge, turn the power off and clean cartridge contacts including the holder contacts, turn it on and return cartridges. You may try borrowing a working ink cartridge of the same type from a friend.
Dec 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
1997 Nissan Altima problem
Check your battery fuse mine just also did that and it was the fuse under the hood. Location of fuse box is by the battery and it should be the big fuse close to the middle
Nov 03, 2008 | 1997 Nissan.5 Altima
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
433 people viewed this question
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
