Question about Proficient S10 Subwoofer
Hooking up I have a AVR - 1804/884 amplifier. How do I hook up my Proficient S10 subwoofer?
0 characters
1 Points
Model S10. Why does it pop when it turns on and off?
This happens to amps/speakers in general. It's not specific to your system. It's caused by momentary changes in power. Please read the following for more detail: Amp causes speaker pop
Feb 24, 2016 | Proficient Speakers & Subwoofers
Instead of base it is making a crackling noise like its blown but i know the speaker is good. any ideas
are you 100% that it is not blown, have you hooked up a meter to check the speakers resitance, if it is a home sun it should be a 8ohm speaker, if you have the owners manual check what impedance it is, if that checck out then try a different cable and then if you can try hooking it up to a friends AVR are you using high or low level inputs on the sub?
Sep 03, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
Power light on but no sound form proficient s12 subwoofer
The power supply is working but it is possible that there is no supply to the SUB WOOFER amplifier. It is important to remove and open the unit to probe and confirm.
It can be failure of the inline fusible due to a faulty output driver.
Finally check the subwoofer using a AA cell.
Oct 16, 2011 | Proficient S12 Subwoofer
I tried hooking up my boston acoustic soundbar to the tv's audio inputs, but i get nothing. if i hook it up to my dish receiver i get sound, but i cant use my bluray, cause its hooked in the receiver. why...
because your tv output is not of suffieient power to drive the soundbar. The soundbar needs to be hooked up to an amplifier that is being fed by your tv line out (or earphone output)
Mar 20, 2011 | Boston Acoustics TVee Model Two TV...
How do i install sub woofers into my 2001 Chevrolet S-10?
dude i have the same problem, im most likely going to attempt to make a shallow box that i can put behind the back seats firing forward. as far as wiring with the s10, half the fun is figuring it out if it works ill let you know...
Nov 18, 2010 | Proficient S10 Subwoofer
How do i hook up the wires from and to a sa wms 315 subwoofer
what r you hooking it to is #1 rca wires r the way to go when hooking up a subwoofer up .some subwoofers have 2 rcas on them one input and one output the in put is mono if what your going to hook it to has rcas on it then the left one is a mono output but if its an audio system then it mit have a subwoofer output on it
Jun 29, 2010 | Sony SA-VA1 Rear Speaker
How do i hook my bose 901 equalizer into deno
The Bose EQ connects to the tape out and tape in on the amplifier or reciever. If you were using these for a tape deck, you will then have to connect the tape deck to the tape in and out on the Bose EQ.
Mar 22, 2009 | Bose 901 VI Main / Stereo Speaker
Connection system
connect satelite speakers to the amplifier and connect signal cable (RC pin) to the woofer from amplifer ie subwoofer out from amp. ok na.
Dec 15, 2008 | JBL 5.1-Channel Home Theater Speaker...
My TV is not compatible with plugged in speakers
yes,just buy any audio video reciever(AVR),you can use this AVR by connecting all your audio and video system,it has a built in amplifier,by using an AVR system it will solve all your problem....
Jan 23, 2008 | Bose Cinemate Digital Home Theater System...
Proficient S10 Subwoofer Logo
Top Proficient Speakers & Subwoofers Experts
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a Proficient Speaker and Subwoofer Expert? Answer questions, earn points and help others
