Question about Nintendo Wii Console
Powering up nintendo wii
When i push the power button on my wii using either the remote or the button on the machine. it lights up blue but nothing comes up on screen and it will not eject or accept discs. the only way i could get it to work was to unplug it leave it for a while and plug it back in again. but even then it doesnt always work. ive only had it a few days. is it something im doing or is this a fault with the wii.
This is a fault with the Wii, you should be able to return it at the store for an equal exchange of another Wii.
Posted on Jan 03, 2008
My wii wirless sencor bar has a blue light on but wont pick up my wii remote
Perform a remote power requirements check. For example, check for batteries in remote control compartments, replace with fresh new batteries for desired operations. Alternatively, the remote control would require power on buttons before functioning with NIntendo. Locate controls power button to initatiate process.
Jan 11, 2011 | Nintendo Mini Wireless Sensor Bar for Wii
Tip
Syncing your Wii-mote to your Nintendo Wii
So you just bought a new Nintendo Wii Remote Controller but when you click the power button the four blue lights at the bottom just blink huh? Well that just means your Remote needs to be synchronized to your Wii.
Here are simple step by step instructions to do so.
1) Turn on your Nintendo Wii.
2) Open the door on the front of your Wii covering the SD card slot and the SYNC button.
3) Open the battery compartment on the back of your Wii-Remote Controller.
4) Press the red SYNC button on your Wii.
5) Press the little red SYNC button on your Wii-Mote.
6) Wait until a solid blue LED light comes on on one of the four lights at the bottom.
7) If it doesn't work the first time, try again.
Your Wii-Mote should now be synchronized.
on Dec 21, 2009 | Nintendo Wii Remote Controller
My wii remote just stopped working in between games and now the 2 bottom lights stay on and the remote won't turn off
Try removing the batteries after you turn off the system. This will turn off the power to your Wii Remote. Once it's off, put the batteries back in and turn on your Wii. If nothing happens on the Wii Remote, then it needs new batteries.
If you're still getting weird errors, push and hold the power button on your Wii for ten seconds. If you have problems after doing this, contact Nintendo at 1-800-255-3700.
Jan 06, 2011 | Nyko Wand? for Nintendo Wii
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
Wii fit board - blue power light flashes then goes off and wont work. This is also happening to my parents one and we are both on our 2nd wii fit board each. Have reset red button but no joy - help please
Unplug the AC adapter from power cord then wait 10 min and plug it again.Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.Then push the red button again, then open the batteries cover on your
Wii Remote and push the red button there.After that push the red button on console one more time, then open the batteries cover on your Wii Fit and push red button there.If this not help may your wii fit need service.
Nov 02, 2009 | Nintendo Wii Fit for Wii
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
New wii remote
Maybee you shou hold the red button?
Nov 08, 2008 | Nintendo Wii Console
Wii remote
Greetings baggie bird,
You need to resynch your remote to your Wii console.
You hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
65 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
