Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
I have Konika Minolta Dimage A2 after swi...
By jouniqe on Oct 27, 2009
I have Konika Minolta Dimage A2 after swich on the view on the screen start shakeing for a few secunds ??
Solution #1
posted on Oct 27, 2009
Not Rated)
Obertelli
Rank: Guru  Cameras & Camcorders  Expert
Rating: 94%, 303 votes
This indicates that the flexible circuit board (flexi pcb) to the LCD has started to crack. usually it happens to the viewfinder LCD first.
Unfortunately it happens to almost all Dimage A1's and A2's eventually and cannot be fixed unless the flexi pcb is replaced. New ones are no longer available and are very difficult to fit due to the extensive disassembly required. If you can get one, you'll find that the weaknesses were never resolved and it's just as prone to failure as the old one. A good used replacement A2 will cost less than any repairs, but is equally prone to the same fate.
All you can do to prevent it getting worse is to never flip out the LCD panel and you should also use double sided foam tape to stick the viewfinder permanently in the down position. Konica Minolta definitely knew of the weakness as they remedied it with a different design in the later A200.
Unfortunately my A2 failed just after I bought three extra batteries and a battery grip for it and the replacement A2 failed a month after purchase. It's a superb camera but seems to have been made to ensure that it doesn't last.
I hope that you've found my answer to be of use and that you can prevent your problem from getting worse. All I ask in return is that you take a moment to rate my answer.
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
best for close up pictures for ebay
Answer
sony digital camera charger
Answer
i cannot install the canon software on my macbookpro because apparently there is 'insufficient... (More)
Answer
I did not realise that my camera had been left switched on and the battery ran flat. Now my lithium... (More)
Answer
i have the dsc-s500 that only stays on for a sec hen turns off....I ran thru 4 ets of batteries with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Digital Cameras:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
