Question about Maytag MSD2434GE Side by Side Refrigerator
Ice Maker Overflowing
Update to existing problem;
I have a Maytag side by side refridgerator with the ice maker on top and the bin below that moves the ice to the door dispenser.
It appears that the tray is refilling before the ice has been dropped into the bin, causing the water to overflow into the bin.
This is causing two major problems; the water in the bin causes the ice to clump together, and freezes the auger, preventing it from turning. the other problem is that the additional water in the tray freezes, creating giant ice cubes that are difficult to cycle, both from the tray and through the dispenser.
I replaced the ice maker itself, but the problem is continuing.
I tested the test points on the ice maker L & N to verify voltage, tested mold heater (71 ohms) adjusted water level, I shorted T & H to run motor and verify cycle including heater function and water fill. I have checked everything I can think of but for whatever reason, every couple of cycles of ice, the tray fills with water and a few minutes later it fills a second time, causing the tray to overflow.
  • Scott Krieger Jan 02, 2008
    I replaced the whole ice maker, so it must be something else, possibly the valves, although i'm not sure how to check/repair it, or should I just replace the valve(s)?
  • Anonymous Mar 27, 2014
    water overflows in the ice maker well
    President:
  • 1,314 Answers
I would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Posted on Jan 02, 2008
  • robert samples Jan 02, 2008
    well if it was me id replace them in case they are sticking you house water pressure opens and closes them but you can check them with the baby bottle method as i out lined its no good ohming the solenoid because they just relieves spring pressure so your house pressure can open them the water valves have a round disc in them with calibrated holes in them your house pressure pushes on the bottom and on the top of this disc this puts the disc in a neutral enviroment on top of this disc is a spring holding it shut when electricity is applied to the solenoid it lifts the spring off the disc and your house pressure pops it open when electricity is removed the spring shuts the valve now because of lime scale a piece of trash the spring may close the valve slowly because the disc cant slide freely so you overfill Even though the valve seems to work
2 Suggested Answers
smilemaker
  • 790 Answers
SOURCE: Ice Maker Issues
HELLO!!!
THIS MAY HELP U ...
http://www.applianceaid.com/icemaker.html#overflowing
Posted on Dec 29, 2007
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
Maytag freezer wont produce ice
You have two sides to the water control valve. One side is for the water coming from fountain and the second side is to refill your ice maker after each cycle of dumping ice into the ice bin. The freezer should be a 5 degrees or below for the ice maker to function properly. If the ice maker is empty then fill with tap water up to top edge of the ice maker and allow to freeze. If after the water freezes and dumps the ice into the ice bin the ice maker does not refill I would recommend replacing part=> 67006009 Dual Water Control Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
Feb 08, 2012 | Refrigerators
Icemaker on our MaytagMTF2156GEW top freezer overflowed with water to the point of overflowing the whole bin that stores the ice, even soaking the floor around the refrigerator. Does the ice maker control...
Good day,
Yes, the ice maker controls the water valve in the sense it turns the valve on for approx. 7 seconds per cycle.
However, it is not the common method for causing flooding. 99% of the issues are caused by the valve refusing to close properly.
The only way the ice maker could be at fault is if it hung at that precise position and refused to advance to it's normal parked position.
However, there is the 1%.
May 29, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE ice maker overflowing
Either your water control valve is leaking while off or ice has formed in the fill tube for the ice maker causing the water to spew in directions other than the ice maker or both. A new water control valve may be needed. Part number WR57X10050 Let me know if this helps. Sea Breeze
Aug 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker problems
the heater on the ice maker has gone bad the easiest way to fix is to replace ice maker.the heater is on the bottom of the maker and heats tray up to harvest ice if it dont the ice will stick.But try taking maker out and cleaning it real good with a light spongee (Scrubee)
let it dry then spray some a light coat of pam (or similar) into ice bins and try that ahrd water will eat the coating off the bins
Dec 29, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MSD2434GE Side by Side Refrigerator Logo
1,667 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
