Question about Hitachi 50UX57B 50" Rear Projection Television
Sony 46WT500 Arched Red Lines appearing. The tv is about 4 years old. I have read on this web site that it is easy to fix, and I am willing to try it, but I do not know how to get the front cover off. Can you help? Thanks.
    Novelist:
    Champion:
  • 232 Answers
NYGirl, the convergence circuit is failing, The IC`s will have to be replaced and all precision resistors will have to be checked, I don`t know who told you this was easy to do but I can assure you it is NOT an easy fix, If you have the service manual, access to a supply house that sells good quality IC`s ( I can give you that number if you think you can do this) a working knowledge of soldering and un-soldering and a good quality voltmeter you can remove the board and do this job, approximate repair time by a qualified tv tech is 2 hours, if not I strongly suggest you call a tv tech, questions? e-mail me back, BMW Rider
Posted on Jan 05, 2008
Picture Falling with arch
It is your convergence IC's going out, they cost about 40 $ for both, if you know someone that can solder, i would have them do it, once you see the new parts it is prity easy to find them on the board in your tv, repair shops usually charge 4 to 5 hundred
Jan 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Arched blue lines across screen of Sony 63" Rear Projection TV
Had this problem bout 2,3 years ago...it was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Good Luck..
Jan 05, 2009 | Sony KP-EF61 61" Rear Projection...
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Dark screen red arched lines
turn down the red screen control slightly the box is located behind the grille 6 knobs on it look carefully for the screen making on it for red do not adjust any other control best done in a dark room with no source in a video input if the tv will not auto align you have the control backed off to far
Oct 06, 2008 | Sony KP-46WT500 46" Rear Projection...
Blue and red arched lines on screen when background dark
Sounds like you are describing retrace lines that could indicate that your CRTs or something in the drive circuits are bad.. Check the resistors on the CRT sockets to see if they are in tolerance. If they are try turning the red and blue screen adjustments down just a little this should take the lines away. You will however be needing service in the not to far future. Turning the screens down should help if the resistors check out. Let me know if you need anything further.
Jan 31, 2008 | Sony KP-48S35 48" Rear Projection...
SONY KP-46WT500 Arched red lines appearing, mostly noticeable when the screen is dark. I have heard there is a simple fix for this problem. I read something needs to be tweaked with screw driver, but i do...
After all the screws are removed, the panel pops on . They use plastic dowls inserted in rubber. The brightness may need to be turned down on the color that has little lines appearing. The brighness is on the picture tube board on each picture tube. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 01, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51HW40
I had the same problem with mine 2 years ago (TV was 1.5 years old at that time) I had extended warranty on TV and it was fixed by Sony at no cost to me. Now yesterday I have another problem with it. All of a sudden screen went BLUE. No Sound either. It could be the CRT (That's what I read here) Out of luck this time. Will call local Repair shop (70 miles away) and see how much it will cost to fix it. Good luck.
May 31, 2007 | Sony KP-51HW40 51" Rear Projection...
Red lines on Sony KP51HW40 Rear projection TV
cold solder on yhe red crt drive.u can find it at the back of red crt try to solder cold joint..or much better if u can refresh all the solder joint. also ,a corrosive terminal of red yoke might also be the culprit. hope this help u...
May 10, 2007 | Sony KP-51HW40 51" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
53 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
